Page 24 of 94 FirstFirst ... 1422232425263474 ... LastLast
Results 231 to 240 of 937
Thread: Another Wreck, another Race Car.....
  1. #231
    Boronia VIC
    Camber tops arrived today. These are seriously well made things!
    Straight forward fit up too will easily get -2.5° of camber without modifying the towers apart from drilling the 4 mounting holes.
    I dropped off the struts for rebuilding today too. They've gone to Top Performance, they'll pull them apart and take a look at the valving and spring rates, work out the best setup and rebuild them.
    If you hadn't guessed it already, I bought these Koni Coil Overs off Dom.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #232
    Aug 2009
    Awesome ingredients in this recipe. Going to make one well baked delicious racecar!
  3. #233
    Any adjustability on those sways? You home over Easter? Will pop in for look if ok.
    Morgs
    76 Mk1 Golf 2dr 20VT BERG (project..)
    01 WRX
    89 SIR CRX
  4. #234
    Jun 2006
    Orange NSW
    I bet those strut tops weren't cheap... But worth every cent.
    Nice work as always, Mr Jones.
  5. #235
    Boronia VIC
    Not cheap at all but much better quality than others at similar prices.
    The integrated spring perch helps get the most travel out of the shock.
    An interesting feature is the bearing system, the spherical bearing isn't taking any axial load.
    The central bearing on GC camber/caster plates is a proprietary bearing, and is made specifically for Ground Control by a US manufacturer. The load rating is 30,500 pounds, and only supports the side load of the shaft. The center bearing DOES NOT support the weight of the car, which is an original and exclusive GC feature. Therfore the load rating of the GC center bearing is incredibly overbuilt for the intended use.
    The seperate bearing for the actual weight of the car, at the top of the spring, is a needle bearing that is specifically designed and manufactured in the US for axial load. This bearing, which has no other purpose than to support the weight of the car is also very overbuilt by design. The AXIAL load rating of this bearing is 12,100 pounds.
    7? MK1 Caddy
    12 Amarok
  6. #236
    Boronia VIC
    Quote Originally Posted by morgs View Post
    Morgs
    No adjustment on the sway bars. I'll be home over most of Easter except for Sunday when I'll be running at Sandown.
    Pop over during the day, I'll be in the driveway
    7? MK1 Caddy
    12 Amarok
  7. #237
    Dec 2007
    Perth, WA. *YAWN*...
    Such good reading! This is the most motivating thread on here at the mo!
  8. #238
    Boronia VIC
    Progress has been a bit slow of late, work's been keeping me busy and I've had plumbing repairs to get sorted at home.
    Here's another couple pieces of the puzzle just arrived today from SCCH via TPR Engineering.
    Electric water pump adapter for the ABF and a rear toe stabiliser kit.
    There's more parts on the way, but you'll have to wait to see those.
    Meanwhile I'm continuing to make progress on the seam welding and rust repairs, it's nearly all done now.
    Hope to start priming it soon.
    7? MK1 Caddy
    12 Amarok
  9. #239
    Jun 2007
    Eastern Suburbs Melbourne
    I'll have to come past once exams are done!
    Will be good to see more progress as always!
    i like volkswagens
  10. #240
    Aug 2005
    Ooh, very nice bits, and great to see some progress I'll be very interested in how the rear setup pans out, so looking forward to your review. Results from others in the UK with similar setups seem to be very good
    Seeing this thread again has reminded me about your head studs, which I'd completely forgotten (!!!). If you still want them, PM your address (not sure I still have it) and I'll express them out tomorrow!!!
