Way cool, Pete.
Don't throw all those bits out.. I'd like to see how much it all weighs when you're finished.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
As Grant pointed out the gadget is pictured earlier in the thread.
The device is a combined punch and flare. It's quite vestatile and can be used to punch a hole, flare an existing hole or punch and flare simultaneously.
They come in a range of sizes from 1 1/2" through to 2 5/8". These holes are 1 1/2" but the diameter of the flared section is about 2".
Here's a link to the manufacturers site. You can buy them off e-bay or places like Summit racing.
Allstar Performance - racing and high performance car parts, accessories and specialty tools.
Summit Racing
As well as removing weight, flaring the edges of the hole stiffens the panel, making it quite rigid.
My reasoning behind perforating the rear apron was to reduce drag, With the wheel well gone it's just hanging in the breeze.
I could have removed the apron entirely but I wanted to keep the shape of the car.
7? MK1 Caddy
12 Amarok
really nice work so far!
Moving a bit slowly this weekend, I slept badly and have put my neck out. Google tells me the condition is Torticollis and that I'll just have to tough it out for a couple of days 'till it sorts itself out.
Anyway... I did manage to get a little more work done during the week and perforated the C pillars. Mostly for looks I guess, that's not a lot of weight saving
7? MK1 Caddy
12 Amarok
just a question pete, i know ive this on many race cars, but what impact does it have on structural integrity if any?
78 2-door 1.8 KR 16v - twin dellorto's
Depends which bits you remove.
In a Golf anything behind the rear shock towers is only there to hold the tail lights up. (From a racing perspective)
Flanging the holes can actually add to the rigidity of the panel whilst removing weight.
7? MK1 Caddy
12 Amarok
With the dollar so strong at the moment I've been doing a bit of shopping.
Finally bit the bullet on sway bars and opted for the lightweight hollow ones from Autotech.
Autotech Sport Tuning: Swaybars
Light weight means lighter race car and less postage , they're only about 10kg.
Front is 25mm and rear is 28mm.
Front bar uses stock mounts and I was able to get a kit with nearly all of the brackets new.
Rear bar uses stock mounts on the beam and custom mounts on the shock tower.
7? MK1 Caddy
12 Amarok
