THAT looks Magic!! it is singing "I go the magic in me" I love the look of bare metal.
looks good! better get that welder out!
Pete, looking at those pics of both the brakes and the shell gives me inspiration. Thanks mate, keep up the good work.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
E mail sent with some welding info Pete.
Shell looks good but get the phosphate onto it quick !!!
Lots of MK 1 Scirocco's...
Cheers,
Grant...
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
looks great Pete! Really is a straight shell!
It's been a busy couple of days.
Got all the loose panels cleaned up and etch primed late last night.
This is the seam sealer/adhesive from around the underside of the bonnet. The dip didn't disolve it but it picked out pretty easily. The rust above was where water had gotten under the sealer.
7? MK1 Caddy
12 Amarok
We tackled the passenger side floor today. Not a trivial task.
Before shots.
I took out the seat mounts as I'll be welding in lower ones for the race seats.
7? MK1 Caddy
12 Amarok
There's three separate patches around the base of the A pillar all of which need replacing as well as the entire floor and part of the sill.
In no particular order here's the removal of old metal and the prep of the new piece.
That's where we left that for the moment, there's jus a bit more trimming to do now before fitting the repair piece.
The repair piece came from Jarred's old Yellow MK1.
7? MK1 Caddy
12 Amarok
Manage to find a bit of time after dinner to get into a bit of seam welding.
The concept here is to stitch rather than laying down a continuous weld to allow some flex and prevent the body from tearing itself apart.
There's a lot more welding to come!
7? MK1 Caddy
12 Amarok
