Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 62
Thread: All Motion 4 Wheel Drive Gearbox Conversion
  1. #41
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by qsilverza View Post
    The Haldex system should be fine, it is reactive but you can make it offensive (Active) These systems run quite a bit of power through them especially with the S3's and I would imagine they would be locked up a lot of the time especially with a Haldex sports conversion which is quite common.
    Are you running a 2.8 ECU or are you going aftermarket ? If aftermarket, and you are looking for constant lock on the rear diff, there is a solenoid valve that has very little electronics that could be bought for $ 400.00 but is only adjustable from underneath the car.
    Otherwise as I mentioned, I am waiting for my contact to finish testing an adjustable haldex controller for in-cabin to work with the original ECU. Will let you know when I have some more information but essentially it sends tricks signals to lock up the diff as per the setting.
    Aftermarket ECU
  2. #42
    May 2007
    Moonee Ponds
    Go teh Proportioning valve ! I will have to dig up the link but it would be the best thing for you.
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
  3. #43
    Nov 2007
    Coffs Harbour
    ok iam back into itits been a headache.....decision pending, looks like going longtunial with motor....
    gearbox is still a prob....which to use
  4. #44
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by JVLR32 View Post
    Thanks all some good ideas....Valver i will post pics
    Boys i cant run the motor longditudinally....reasons is due to the way the rollcage and chassis design was done
    The car orignally ran a subie motor and a Lbox (beetle with straight cuts and albins. quaife.
    Everything is quiet clear wat you boys are explaining!...I no pics could help but i have a 6 speed box and 2.8 motor ,i have the allmotion 4wd set up
    I want the gearbox to only operate the rear 2wd..?I dont need to operate the frnt wheel drive...
    If somone can host some pics for me that would be great..this will show the car..PLEASE
    My comment above went out the door
    ok will a audi 1.8T box fit?
    audi non turbo?
    can someone give me make model dates please? and also how strong are these boxes.
    Iam thinkin maybe a G50 box from a Porsche could also be the way to go
  5. #45
    May 2009
    Perth
    Not sure about mating boxes to engines. But if you go the G50 you will need to get the box modified to run in true middy config (I believe it needs to be run upside down and if you want it to survive it needs oil line mods) = $$$ and only a real option if you need to put silly power through it IMO.
    The passat and A6 longitudinal design 'should' just bolt up with flywheel, clutch and starter.
  6. #46
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by IanJ View Post
    Thanks Ian....the 0E1 passat ive been told
    will fitthe box will have ppg inserted for extra strenght.Now i need to find one forsale.
    So is the.
    A6 stronger or passat?
  7. #47
    May 2009
    Perth
    I guess most of them will be the same. I'd be more interested in ratios (diesel v's petrol?)
  8. #48
    Nov 2007
    Coffs Harbour
    Nov 2007
    Coffs Harbour
    thought update this alittle....A Subie box, all parts avaliable and can be converted.....
  10. #50
    May 2009
    Perth
    FWD Subie box? Or a hacked awd?
