Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: All Motion 4 Wheel Drive Gearbox Conversion
    Nov 2007
    Coffs Harbour
    Hi all,
    Does anybody know how to convert a 4 wheel drive box back to two wheel?
    My plan is to only use the drive shalf (diff)to the transfer case for rear wheel drive.
    How do i mod the front wheel drive from spinning?
    This set up is going in a beetle mid mount setup
    Aug 2005
    I'm assuming you're using a VR6-family engine?
    Just use a Mk3 12v VR6 02A bellhousing (or complete box) and lose the AWD box altogether. Change to a 228mm clutch and flywheel setup and you're done.
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by Valver. View Post
    Its the 24valve VR6 motor (bora)....Its hard to explain! Iam running a tube chassis...and want to mid mount the engine But cant get it back far enough to use the front drives of the box! ..so some how i need to plug them up and use the transfer case with a cut down tail shaft....
    Nov 2007
    Coffs Harbour
    any other ideas
    Aug 2005
    TBH, I think you have backed yourself into a corner! You either run a proper MR setup with a FWD gearbox or an FR layout and a traditional length propshaft!!!
    Nov 2007
    Coffs Harbour
    thanks valver!
    May 2007
    Moonee Ponds
    What are you going to do ? JVLR ? Got any pics ?
    In America's I have seen how the guy modded the Haldex to be always on You could try that ?
    Nov 2007
    Coffs Harbour
    apparently i can do something with the viscous gears!!!!...no pics at moment m8.
    May 2007
    Moonee Ponds
    So it's a quattro AWD system ?
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by qsilverza View Post
    no m8! 6speed all motion out of a bora the 24valve
