This is easy, the AWD 6 speed 02M gearbox as found in the Bora 4 motion can easily be converted to 2wd.
Remove the transfer box and make a plate that bolts onto the gearbox case to hold the output shaft seal, you will need to get an output drive flange from a 02M 2wd gearbox though to make it work- these are not hard to find in the USA.
thanks.......really u have given some good insight
