can you just run a beefed up kombi box with an adaptor plate ?, you can make the box run the other direction when you rebuild it. short of that what about a g50 or g50+50 box out of a porsche like all the midengine sports cars ? you can make adaptors for anything pretty much
cheers brenton
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
I really dont think we are on the same wavelength with this .
The bellhousing pattern on a VR6 gearbox is completely different due to the timing chain cover coming out on one side . An adapter plate would need to be thick enough to be able to be bolted on without hitting the timing chain cover . There is a reason why 02a and 02m gearboxes are completely different in the casing between the 02j and 02m 4 cylinder units .
Audi was never released with the VR6 engine apart from the TT which basically has the same box as an R32 . The only locally north south gearbox which has the unique bellhousing for the VR6 is the 5 cylinder b5.5 Passat , but they are auto only .
Next time you got a chance go look at a VR6 engine and the bellhousing of a VR6 gearbox and then compare it to almost any 4 cylinder VW/Audi and you will see what Im talking about
What about the 5 cylinder Audi A4 gearbox? Surely thats the same bellhousing as the Passat and so will fit the VR6?
Never heard or seen a 5 cylinder audi a4 .
Neither have I ??
according to the internet, there were indeed no 5-cyl a4's.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
What about the 6cyl A4s? Will one of those boxes bolt up to the vr6??
The Haldex system should be fine, it is reactive but you can make it offensive (Active) These systems run quite a bit of power through them especially with the S3's and I would imagine they would be locked up a lot of the time especially with a Haldex sports conversion which is quite common.
Are you running a 2.8 ECU or are you going aftermarket ? If aftermarket, and you are looking for constant lock on the rear diff, there is a solenoid valve that has very little electronics that could be bought for $ 400.00 but is only adjustable from underneath the car.
Otherwise as I mentioned, I am waiting for my contact to finish testing an adjustable haldex controller for in-cabin to work with the original ECU. Will let you know when I have some more information but essentially it sends tricks signals to lock up the diff as per the setting.
Audi B4 80 Q V6 '94 Race Car !! KEGGED
Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
--VW Bora V6 4mo '01 Gone
