Results 1 to 10 of 17
Thread: adz conversion
    adz conversion
    hey i'm wanting to do a adz conversion to a b1 passat,
    i will run into troubles with the oil filter fouling on the side engine mount, the old oil filter holder obviously doesn't fit, my question is,
    wat can can i get an oilfilter holder off, i believe i will need a holder off a A4, or passat it needs to slant towards the back of the motor
    will a AEB oil filter holder fit onto a ADZ block,
    any help appreciated
    cheers Nick
    Camden, Sydney
    I did the same conversion and the troble you have is that the later passat and audi engines have more sensor holes etc and the later engines have a different shaped filter housing.
    2E engined passat from the UK would be the one you want.
    What I ended up doing was using the filter and housing off the adz motor and cutting a chunk out of the engine mount to allow clearance and then making a strong, but funny shaped engine mount incorporating a holder for the clutch cable.
    What about an oil filter relocation kit?
    the adz is a great motor for a cheap and easy upgrade. good head for mating up to a stock carby manifold.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Quote Originally Posted by Lorenz View Post
    i have considered that, bout $150.
    probably what i will end up doing,
    what about a oil filter holder off a 1.9e Audi 80 engine? any one know? pics?
    more problems with the conversion, while looking over the engine arrangement i noticed the the alt is running off a multi-V belt, and the alt is the tensioner for the air con pully
    the water pump is tensioned with the power steering pump, as you are all well aware,
    i'm not running the power steering pump so i have nuthing to tension the water pump pulley, if i run the new alternator
    how have people got around this, run a dry power steer pump?
    Boronia VIC
    I think you can change the waterpump pulley to a VR6 one and run it off the serpentine belt, that way you don't need the other belt at all. You'll need a different length belt though.
    We're discussing similar issues over here http://www.vwwatercooled.org.au/newf...ad.php?t=18077
    Pete
    i can't run that setup! the alternator will collide with the radiator in the B1,
    golf loon, how'd ya get around this custom pulley's?
    we'll the conclusion to this is the old alternator setup, with the old crank pulley, and a custom made water pump pulley!
    i don't think i have many other options, or this been the simplest!
    Gosford Central Coast NSW
    you can run a power steer pump, but not dry - it needs fluid for the bearing as i understand.
    if you pull apart the pump and remove the vanes, you can then run it without it pumping - it just turns round and round - fill it with fluid and cap the hoses.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
