Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 62
Thread: A3 1.8T makeover....
  1. #21
    The adaptors I needed to begin flashing the Eeprom arrived from Canada yesterday but I've stuffed up and the 'cheaper' one I bought doesn't fit my particular programmer Doh !!!. I tried to find a suitable option in Sydney yesterday either the adaptor or even borrow and older style programmer but had no luck. So the remap will have to wait another 1~2 weeks till the correct part turns up. I'm still going to call up a few favours from old Telco contacts today but its not looking good. Every place had this gear 10 years ago but not anymore, Damn ! . I really wanted this on the dyno tomorrow
    I'll put up some ignition timing tables a bit later and show just how much more timing is added with the remap even under full boost in fact double the original 8.7 psi. These engines are so wound back.
    I'm going to put in a spare Blitz DSBC this afternoon. The mixture was quite rich in stock form so it will give me a bit of grunt albeit with reduced timing. Not ideal of course but I'll see how it goes
  2. #22
    The Blitz DSBC is partially in, I'll have it ready by the morning. I have to take the STI over to Tunehouse at Marrickville in the morning for a WRX dyno day then I'll most likely take the A3 over to Turbo XS at hornsby and possibly achieve the lowest figure of the day at the moment its around the same power as a stock MkV TDI 2L except minus the torque. I'll just run the blitz up to a flat 11psi I'll start at 9 and go from there. On the dyno the fueling was fairly rich so theres a bit of a margin but not too much so I'll just see how we go. The final proper tune covers all the alterations to Fueling, Ignition and boost. I'm pretty disappointed I can't run it tomorrow but such it life
    Here is one of the timing maps that I will be using in the ECU once I order the correct part
    The 3D map shows the difference over the stock 110kW map.you can see in some places there is a 7 degree advance. This rom is setup for 98 RON so no funny racegas business either. I personally don't like to run anything other than 98.
  3. #23
    Dec 2007
    Melburg East VIC
    nice work on the tune
    is that 3" cat & res going into 2.5''?
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
  4. #24
    Quote Originally Posted by schwartza3 View Post
    No its far worse, that last dodgy looking weld joins on to the factory rear section and muffler . I'm being given another one shortly so I'll put that on and join it there.
    This tune is a 'shelf' stage tune the reason being I haven't done an A3 1.8T with this Motronic 3.8.3 ECU before so rather than guess I start from the base, test it and work either forward or even backward from there. I really need to convert the ECU to accept a socket for fast eeprom changes.
    All the maps are nice an progressive no dodgy jumps. . I've by passed the boost solenoid and its restrictor and now have the blitz plumbed in very temporarily.
    I'm thinking about this guy If I keep the car long enough or if I get bored
    http://cgi.ebay.com/ebaymotors/ws/eB...m=370365841766
    It has bigger turbine and comp wheels but I'm unsure of the housings A/R given its K03 or K04-1 based (maybe its not either)
  5. #25
    Bit of an update. I still don't have the necessary hardware to talk to the flash yet nor has the silicone pipe work hasn't turned up so all I've been able to do is rip out the alarm. I can't identify what brand it is even from its PCB and without a remote its just a PIA. I therefore don't have remote central locking and I have to lock and open thte car with a key - how last century
    I have fitted a Blitz DSBC SBCiDII which is a very good boost controller, its a little bit hard to setup if you don't know what your doing but rock solid once you get your head around it. As well as being able to control boost very well it can log manifold pressure graphically and thats what I'm mainly after. A quick squirt around the streets shows that something is amiss. Even with the factory boost control removed from the system and boost set to 10 psi flat, boost drops after say 3500 rpm to wastegate acutator spring pressure which is approximately 8.7 psi. It might even be less than this.
    So the next step is to find whats leaking, there is a faint rattling sound from near the turbo ( is this what the K03s sound like when dieing ) but it could be another leaking hose, the PCV setup, the BOV setup, part of the stock boost control or the wastegate spring or actuator.
    Any hints of what commonly dies much appreciated
  6. #26
    Some stuff turned up finally. A couple of breather pipes appear to have been left out Grrrr.
    Now for the remap....
    Yep some stuff I need for this.... and a Volvo T5R
  7. #27
    Mar 2010
    Wollongong, NSW
    Something tells me you will be updating your sig very soon
    MY08/DSG/Recode Stage 1 Remap/161.7kw/Eurojet DP.
  8. #28
    Quote Originally Posted by HOTHATCH View Post
    Chip mods complete and now I have mega wheelspin for some strange reason LOL
    Original flash Eprom removed and board cleaned up
    Original data is read and stored (just in case) and the new modifed data written back on
    A tiny 1mm tip on this iron, only 10~13 watts but its all you need, in fact it could be smaller. I'm going to use sockets from now on what a PIA
    I'll post up some maps a bit later. I'm still in the process of swapping over lots of prett silicone pipes. The dumpvalve is fluttering, infact I'm sure its not venting at low pressures and its certainly leaking up top. It sounds very much like my Garrett GT35R on my other car with the BOV blocked . This is not good on a K03 Borg Warner
    The car hammers I wish it had AWD
  9. #29
    Jan 2009
    blankedy
    Hi mate,
    coming along I see...
    Would love to see some mapping in action. Drop me a PM when you're going to be playing God and I'll come look over your shoulder and ask lots of annoying questions.
  10. #30
    Dec 2007
    Melburg East VIC
    Quote Originally Posted by parso_rex View Post
    that's impressive!
    i'm assuming this is how all the custom mapping is done in uk rather than what we get here in oz (generic chip)
    i'm pretty sure you'd be the first one in oz to do this yourself
    get some rollers and open up a business!
