Page 7 of 7 FirstFirst ... 567
Results 61 to 67 of 67
Thread: 93 cabrio repairs...
  1. #61
    Perth. WA
    Quote Originally Posted by cab93 View Post
    I've heard silver paint can be difficult to match, but yours looks perfect.
    The paint was a pain in the a$$, would have done the whole car given time and a decent spray booth. Worked out it had been resprayed before,likely with a non original mix. Metalics are the hardest to match to existing paintwork .
    Just a quick question on your clock replacement. After removing the cluster from the dash, how is the clock held in? Soldered or a push fit? Is replacement straight forward or did you need a auto electrician?
    Mine has started to bleed and will need replacing.
    Thanks
    Michael
    Clock assembly comes out pretty easily after you take the wiring foil off ( carefully) and remove the tacho out of the cluster.Clock is held in with 2 tiny screws. no solder required, did a ton of wiring work while the dash was out, only used a BentleyManual wiring diagram.
    Had a web link for replacement clock in China, but couldnt get any sense from the company, ended up using one from a different cluster, altho its started bleeding now... Will leave it for the time being.
    HTH, Grant.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  2. #62
    Perth. WA
    Quote Originally Posted by GoLfMan View Post
    looks the business Grant!
    Just re-read the whole thing myself, awesome, any updates???
    Anything particular your interested in Josh ?? next bit will be either the brake overhaul or the top replacement, hopefully before December so my girl can use it while she is here from UK.
    Cheers,
    Grant...
  3. #63
    Feb 2006
    Perth Western Australia
    Looking Grant, keep up the good work mate
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
  4. #64
    Jun 2007
    Country Victoria
    Thumbs up
    [QUOTE
    HTH, Grant.[/QUOTE]
    Thanks for the info, I guess it's direct sunlight that causes them to leak?
    Now to find an old cluster!
    Michael
  5. #65
    Perth. WA
    Not sure about the sun, think its more from the LCD screen being tweaked by overtensioning the screws as the one i replaced it with was clear when installed.
    Out of 9 clusters i found only 1 that worked with all bars in the LCD operating...
    You can check them when out of the cluster ( tho i cant remember how ) think a power and earth connection was all it took.
    Cheers,
    Grant...
  6. #66
    Jun 2007
    Country Victoria
    Quote Originally Posted by roccodingo View Post
    With my clock, if the battery has been disconnected for a period of time then reconnected the numbers are incomplete. I find that pushing the hour or minute button and letting the numbers scroll, will sort the problem. Hopefully they may still work.
    How did you find nine? I've only ever found one in Melbourne - at the time I didn't need it. Do you know a good auto dismantler of old Golfs?
    Michael
  7. #67
    Perth. WA
    Yeah, the bars sometimes arent working on mine , then drive the car and there all fine ( dunno how that works..)
    I buy them from the US, UK wherever some are destined for MK1 Scirocco upgrades.
    Bout the best you can do for real old Mk1 stuff is either California or Arizona wreckers, Even UK is getting difficult to find bits nowdays.
    Cheers,
    Grant...
