![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Jarred
and thus the project budget gets blown out of the water! hahaha
Wouldnt be the first time either...![Emo Duh](https://www.vwwatercooled.com.au/forums/images/smilies/emo_duh.gif)
Finally got the paint on, thought the colour looked a bit dark so took the paint back to the supplier with the original guard as a sample... by the look of it it still looks a bit to blue compared to the rest of the car, but will suffice for now...
![](http://i4.photobucket.com/albums/y140/roccodingo/frontrightpaintres.jpg)
The bonnet is still to the left a wee bit ( check gaps..) will have to sus that out later...
![](http://i4.photobucket.com/albums/y140/roccodingo/frontpaintres.jpg)
managed to get the block striped out and into a hot tank, removing all the rubbish out of the water passages in the block, have replaced near everything else with the cooling system, so grotty block needed sorting..
![](http://i4.photobucket.com/albums/y140/roccodingo/Inthewasherres.jpg)
and thats the robowash... caustic hot tank is a different set up by far...
well all the bits came back to my shed, painted the block, then began the reassembly..
the caustic eats the whitemetal auxillary shaft bearings, so they needed replacing ...
![](http://i4.photobucket.com/albums/y140/roccodingo/pullinginrearauxshaftbrgres.jpg)
had the puller guides from a previous car rebuild, so makes short work of it..
got the crank in...
![](http://i4.photobucket.com/albums/y140/roccodingo/crankinbedres.jpg)
all the pistons, rods etc are in , clearances checked and torqued up..
Sump is on, front mount, rear dividing plate and the pressure plate..have a couple of alloy pipe flanges that need blasting, so they will go on during the week..
![](http://i4.photobucket.com/albums/y140/roccodingo/bottomendaboutdone2res.jpg)
more tomorrow....
Reason: falling asleep....ZzzZZZzzzZZZzzzzzz
Lots of MK 1 Scirocco's...
Cheers,
Grant...
