Got the hood on, seems like it all needs to come over to the right a few mils... may have to bend the hinges or shim it with a washer ...
Least the guards are on and there staying there...
..to be continued...
primed and painted the lower hidden section of the A pillar, had shown some light rust on the previously only primed surface.. so some top coat will only serve to protect it more IMO...
So anyone know what this little sucker is about ????
Fitted the guards up, bit of a bugger getiing them anywhere near in line...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Cheers,
Grant...
hell yeah! great work.... cant wait to fiddle with mine now'
dom
Great work Grant looking great mate!!!
yeah, should be able to do that Joe. Wont happen before March tho as i'm on a tight schedule.
lemme know if you need to borrow them to strip a trans.
More sanding tonite, stripped the engine also bar that darn crankshaft sprocket bolt...![]()
Cheers,
Grant...
Not sure if any of the O2O tools are the same for an O2A Wade...will have a gawk at the manual if i get a chance...
More time in the paint shed today seeing the week was shot down with the workload..
Primered the front of the car completely now, needs a rub back down to 800 for the metalic paint...
Cheers,
Grant...
Then onto the bumper and one arch section that needed replacing ..
sprayed it with the plastic flex primer.. 2 coats...
then over that with 2 of the primer filler...
Tomorrow will give them a light rub once again down to 800 grit wet..then hopefully enough daylight left to get the base and clear coat on it all...
Yeah, new shed with no power....
The engine was only going to get seals and gaskets replaced, but now its totally in bits...doing the bearings, re ring and a deglaze hone, valves can have a grind along with the seats. New guides if warranted...got all the goodies on their way, set rod bolts, set head bolts...gaskets, seals, all the coolant hoses, timing belt and tensioner...In my book, do it once, do it right...bugger the wallet....![]()
Cheers,
Grant...
looking awesome Grant, great stuff
keep it comin!
