Results 1 to 9 of 9
Thread: 8v Engine??
    Apr 2009
    8v Engine??
    This coming summer i'm planning on swapping out my 1.6l 8v to a larger 1.8l or 2.0l 8v. The car is just going to be my daily driver and am after reliability more than power. So between now and summer im trying to hunt down a good condition 8v engine. My original plan was to get a AGG engine and run it on a 32/36 carb, However after some reading I think I might do it properly and take the fuel injection system from the Mk3 GTI 8v and run that.
    This engine will be going in a 1975 Passat TS so I am aware that I need to make 1 of the engine mounts.
    Just after some advice on what you guys think about the AGG motor or if you recommend going 1.8l over 2.0l since i've read that some people prefer it more.
    Also if there is a detailed write up of a similar fuel injection conversion with a 2.0l 8v motor into a Mk1 golf or Passat that someone knows off. (I've searched this forum but have been unsuccessful)
    -'75 Passat TS
    -'75 Passat TS (Project)
    No....its not a Piss-sat its a Pass-sat!!
    Gosford Central Coast NSW
    Huss,
    If you want to swap over the whole fuel injection loom then you'd just about be better off to buy a cheap seat cordoba or mk3 golf and take the entire wiring loom and engine out and swap the lot over.
    otherwise look for any 8V thats to your liking and just run the 32/36 carb on it. You should be able to mount up just about any of the 8V engines with the existing brackets that you have on your 1.6
    for the money to do the swap over to a later 8v petrol with the loom, I wouldnt bother - i'd be looking for a 1.9 diesel to put in there instead (with a turbo) - but thats just me.
    I've moved this to the "conversions" forum for you aswell.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Apr 2009
    So are there any particular high compression 8v engine models which are better than other models, I just figured an AGG would be a good engine to swap since it came out of the Mk3 GTI models.
    -'75 Passat TS
    Specs for the AGG motor look good
    85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 166 newton metres (122 ft·lbf) @ 2,600 rpm — AGG
    Here's a few specs for 1.8 motors
    Output ----------------- Torque -------------------- Compression Engine code
    55 kW (74 hp)/5000 rpm 140 N·m (100 lb·ft)/2500 rpm 9.0:1 AAM; ANN
    63.5 kW (85 hp)/5200 rpm 133 N·m (98 lb·ft)/3000 rpm 8.5:1 GX
    66 kW (89 hp)/5400 rpm 142 N·m (105 lb·ft)/2600 rpm 9.0:1 RP
    66 kW (89 hp)/5500 rpm 145 N·m (107 lb·ft)/2500 rpm 10.0:1 ABS; ADZ; ANP
    67 kW (90 hp)/5500 rpm 142 N·m (105 lb·ft)/3000 rpm 8.5:1 JH
    72 kW (97 hp)/5400 rpm 142 N·m (105 lb·ft)/3000 rpm 10.0:1 2H
    82 kW (110 hp)/5800 rpm 154 N·m (114 lb·ft)/3500 rpm 10.0:1 PB; EV; KT; JJ; DX
    I was looking at the Audi 1.9 for my car
    83 kW (113 hp) at 5600 rpm, 160 N·m (120 ft·lbf) at 3400 rpm
    2.0 litre motors
    80 kilowatts (109 PS; 107 bhp) @ 5,400 rpm; 160 newton metres (118 ft·lbf) @ 3,500 rpm — BSX
    85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 165 newton metres (122 ft·lbf) @ 3,200 rpm — AWG, AWF
    85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 166 newton metres (122 ft·lbf) @ 3,200 rpm — 2E, ADY, ABA
    85 kilowatts (116 PS; 114 bhp) @ 5,200 rpm; 170 newton metres (125 ft·lbf) @ 2,400 rpm — APK, AQY
    85 kilowatts (116 PS; 114 bhp) @ 5,200 rpm; 170 newton metres (125 ft·lbf) @ 2,600 rpm — ATM
    85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 172 newton metres (127 ft·lbf) @ 3,200 rpm — AZH, AZJ
    85 kilowatts (116 PS; 114 bhp) @ 5,400 rpm; 172 newton metres (127 ft·lbf) @ 3,500 rpm — AZM
    88 kilowatts (120 PS; 118 bhp) @ 5,600 rpm; 174 newton metres (128 ft·lbf) @ 2,400 rpm — ATF
    88 kilowatts (120 PS; 118 bhp) @ 5,600 rpm; 175 newton metres (129 ft·lbf) @ 2,600 rpm — AUZ, ASU, AVA
    Hope this helps
    Paul
    trouble is most of them aren't particularly available.
    The ADZ, RV and GX 1.8's are common, and the 2E and ADY are locally fairly available aswell, but a lot of the other ones are euro-spec. I have an EV in my garage just sitting there with some k-jet bits on it.
    Not many mk3 GTI's (if any) in australia... I've heard of 1.
    '99 A4 Quattro 1.8T
    Sep 2009
    Chillaxing in Tas
    The ABS 1.8L is great, slap a weber 32/36, set of extractors, electric distributor, and a mild cam and it will hold its own on many newer cars up to 100kay, if not more.
    I had a 1.8L with a weber, 276 cam, and extractors. and i have to say it was quicker then a 2E 2L with extractors and cold air intake.
    The 2E had better torque but when the cam came on song in the 1.8 it would rev clean off the stock tacho and into the fuel gauge. redline in 2nd was 100kays with a 4 speed diesel box.
    <space for rent>
    May 2012
    Tullamarine
    Hey guys I'm just in a predicament at the moment. I've got a 4speed diesel gear box and I just brought a 1.8l 8 vale engine block, im about to replace the clutch before Assembling them together, is there a specific clutch I need to install or just a standard NA clutch.
    any clutch you have that fits will work fine.
    Quote Originally Posted by 5teve View Post
    '99 A4 Quattro 1.8T
    Jul 2011
    eastern suburbs. melb
    Huss,
    Just wondering what diesels you are talking about here and what they come out of. I have been having evil thoughts able a 1.9 diesel conversion but they dont seem to be readily available. definitely not to the extent that they are in America.
