Finished product. I finished it off with the flapper wheels. They work awesome at smooth everything out!
Redline adapter
Intake Manifold
I blended in the opening into the first port runner as smooth as I could. I'm not a pro at this. Just enjoy doing it! haha
With the adapter mounted up. I tried to make the transition as smooth as possible without sharp edges or turn's & blended it into the manifold.
Came up ok I reckon
With the throttle mounted up. I also tapped & inserted a bung into one of the fitting's I didn't need in the intake too. I only need one fitting for the brake booster.
Open wide!!!!!
I'm not too worried about port matching to head at the moment. If the engine blows a headgasket & I remove & dismantle the head, I'll do it then. But can't be stuff with the engine still in the car.
I'll also do the exhaust manifold too when it turn's up, but I'll only match it to the exhaust manifold gasket's.
Enjoy
