Still pretty clean for a 380+K engine. Also a TT276 in there too!
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1662-1.jpg)
It wasn't this clean 10mins before I took this pic, that's for sure.
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1663-1.jpg)
All ready with the 5spd to go into the car tomorrow morning.
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1664-1.jpg)
The ol' girl's looking pretty bare now. Also note the oil sweat from the dipstick tube. This was caused by excessive crankcase pressure buildup, even though it has a 1" breather tube. I can't wait to tear it down for further inspection.
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1665-1.jpg)
Hanging in the breeze. Just airing out the burn't front tyres! Ha haaa
Well I fitted the other engine this morning in the rain & is running ok & also done the CO% tune. Was only out by a fraction of f@#k all.
Took 2hr's to refit everything & fire it up.
Car started up straight away after regaining fuel pressure. Oil pressure light went off straight away too!
I decided on fitting the vernier & lightweight pulley's & also took some time to replace the fuel injector braided lines while I was playing around, as I already had them here off the GTI.
Total cost of engine swap. $2! I needed a gasket & didn't have one lying around anywhere.
It doesn't go anywhere near as hard as the original one & in my eye's not very impressive at all, but it will have to do.
Nice to have the Autotech 270 & 5spd again too! Can just cruise along in 5th @ 50kph nice & smooth.
I was right about the valve stem seal's. Only alittle smokey when cold. Not too bad though.
Will go into Vic Road's on Friday to have the engine sighted.
I may also fit the original GTI dizzy with vac advance for an increase in fuel ecomony next weekend & see how it goes. Not interested in performance for this car anymore, as spending any money on this engine is a bloody waist.
I'd like to get around an honest 460+km out of a tank.
You can't even tell the difference. Look's identical, apart from a clean breather bottle!
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1668-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1669-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1667-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1670-1.jpg)
The aftermath of an engine swap. Took nearly just as long to clean up everything than it did to refit the engine & box!
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1671-1.jpg)
Also have to thank the two JJ's for their hand removing the engine & box. It's nice to get a hand doing these sort of job's without engine cranes etc.
Alway's good to catch up with you guy's for a chin wag.
Haven't been on here much lately, but thought I should give a little update on the 76er.
The instrument cluster finally clicked over half a mill! It only had 10K left to do when I pulled the interior out of my old silver beater.
I've now travelled 10k since building this car too!
I know, I know. I still haven't washed it. 10K of dirt, road grime, brake dust & build up. It's on the "Thing's to do" list, along with a couple of rattle's & squeaks.
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/IMGP1675-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/07/Imgp1674-1.jpg)
Alittle update on the old girl.
My quest for fuel economy is on pretty good track & recently got 8.9L/100km combined highway/city & about 450km for a tank of juice. The speedo is also spot on 100% with the 5spd & 16" wheels.
I've just fitted the GTI vac. advance dizzy today & hopefully this will come down even further. Will update on progress.
I could also refit the stock K-Jet fuel dizzy & airflap, which will bring it down again, but its not in too good a condition.
I know it's not much to write home about compared to diesel's & new car's but it's pretty good for some very old technology.
Also doesn't come close to the Audi's 6.7L/100km. May have to rob some K-Jet & aux. air part's off it if it doesn't sell soon & wreck it out.
I thought I'd give an update to the "what's going on" with this car so far, 6 month's on from being built.
Lately it's been driven, hammered, loaned out as it's turned into a bit of a community car of late. Also known as the "show car/loan car"
But some work has been done on it.
I had both the front seat's repaired by a well known & top notch upholster in Melb.
It wasn't cheap, but the result's were worth it I reckon.
They repaired & double stitched all the pleat's on the base & backrest & also added in a new vinyl section across the top of the seat with piping where they get very bad sun damage, causing the material to shrink, split & tear.
They also gave me some extra vinyl material for the back seat across the top too when it need's it.
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/11/Imgp1926-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/11/Imgp1923-1.jpg)
![](http://www.vwwatercooled.com.au/forums/images/imported/2008/11/Imgp1924-1.jpg)
Since all this was built, its been used as a everydayer & has so far clocked 533+K
I've also since added a slight power upgrade to it, but I'll do another build thread on that.
- You may not post replies
- You may not edit your posts
Forum Rules
