Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 20v 1781cc Turbo engine into Mk1 Golf
    Nov 2006
    north fitzroy, victoria
    Has anybody got any knowledge or know of somebody who has done this conversion? Car currently runs a fuel injected 1781cc Audi motor with mechanical injection. This conversion seems to be all the go in the UK according to Golf+ magazine. . . .
    Jul 2005
    Melbourne, Williamstown
    All I know Rob, is that unless it's an older unit you'll need an aftermarket ECU, you've probably read about all the kits available in the mags.
    TassieGti is doing this conversion, think he has a thread on it somewhere.
    mk2 GTi 16v
    Corrado G60
    Custom-Code.co.uk can defeat the immobiliser for an extra £100 over the cost of a chip. Providing you arent going to a big turbo etc that'll be cheaper than going standalone.
    shailen vw Guest
    Quote Originally Posted by fourbtoo
    I used to be involved in vw golf conversions back in south africa
    did a similar conversion /used golf 1V engine & trans with programable management system
    easiast way to do this buy complete front of golf 1V if possible
    there is many ways of doing this all depends on what kw u want at the wheels
    Feb 2006
    Camberwell, Victoria
    Apparently a passat 1.8t will bolt straight in using mk1 diesel mounts...speak to golfworx more about it...
    I am sure the block would fit great but its not transverse so you'd need a sump and oil pickup before you started.
    Any 1.8T loginitudinal engine will bolt straight up to your existing RHS engine mount.( I prefer to use a modified diesel mount's as they are of the bigger variety) As Gavin said you need a different sump & oil pick up. Also the intake will have to be modified too.
    Using a transverse 1.8T require's a fabricated RHS mount & swapping the hydraulic cambelt tensioner to a 16V type with a stud. Not to difficult to make.
    There's a few more thing's to consider but I hope this gives you some help.
    Tim.
    Jul 2005
    Only AEB's with the external water pump will still have the bolt holes for the rhs mount, the later engines have the same internal pump as the AGU engines and no way to directly bolt on the mount.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jul 2005
    Continuing along this vein, can you take the ignition barrel, instrument panel and wiring from the donor vehicle and make it work in the new vehicle without having problems with the immobilizer?
    mk2 GTi 16v
    Corrado G60
    Albury, NSW Australia
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  3. Will 1980 Passat Engine fit in 1979 Golf GLD??
    By hvellacott in forum Diesels
    Last Post: 26-09-2006, 07:22 PM
