Results 31 to 37 of 37
Thread: 2.5TDI + bi-vnt-turbo
  1. #31
    Here's my fake D2 rear brakes. They are bigger and much stronger than original front set.
    VW T4 2.5TDI 350hp, 700Nm @2,2bar. 2000kg with aerodynamics of a barn door.
    14,53s 158,8kmh @1/4-mile
    http://www.youtube.com/watch?v=hkSTslJf7Z4
  2. #32
    Fitting new angel eye headlights from long nose. I think it will look mean after I'm done...
    Of course it would be much easier to make it a long nose as I already have all the parts for it. It's just that nothing is ment to be easy with this build...
    This way I can also shave some 30kg out of my heavy van.
  3. #33
    Here's the original look.
    I'm trying to make the hood out of CF eventually, but really don't know how it's going to work out. We'll see.
  4. #34
    keep up the good work
  5. #35
    Quote Originally Posted by GoLfMan View Post
    I'll try my best. I just hope it gets finished before I go bankrupt...
    Here's the rear ARB finally in place (shiny metallic piece on the lower arm is the end of ARB and on left upper corner you can see ARB's attacment to the body).
    Front brake kit. 330/32mm with 8 pistons.
  6. #36
    8 piston callipers... holy crap
  7. #37
    8 front, 4 rear. It's a heavy van although maybe 200kg lighter than it used to be.
    It's time to sort out the shocks.
