The dizzy that comes with the 2 litre most likely has no advance mechanism ( done electronically by the ECU ) so to run weber's you will need to swap to an older unit with mech, vacuum or a combination of those advance types.
In Anton's 2E swap ( that is going to the dyno Sat morning ) we used a Mk1 1.8 dizzy with the vac advance and retard set to EG GTI mk1 timing specs. Will be interesting to see the torque curve that it generates.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
