I think black should be live.
have both module and tci switch
ignition switched +ve to coil positive
have Black and Black/white wires to coil +ve
green to -ve coil
have thick Black wire from tci switch to earth (this one im uncertain)
have hall sensor plugged in
have Brown to earth
owned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
when i put that wire with the thick black sheath and brown inner to +ve the ingition lights comes on even with the ingition switched off.
not sure whats going on thanks for the responce guys
You probably have the wires to the coil on the opposite sides.
Brown is always earth. Black is ignition +.(15)
Don't worry about sheath as they are always black or grey.
Hope his helps,
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Looks like Gold roccodingo.![]()
thanks for the responce Brown wire black sheath was negitive..
Got spark yeah!
got a vw cabrio relay for the fuel pump got it wired sweet
this project is finally coming together
