Results 1 to 10 of 12
Thread: 16v factory ignition module wiring
    sydney/ cessnock
    Red face 16v factory ignition module wiring
    have both module and tci switch
    ignition switched +ve to coil positive
    have Black and Black/white wires to coil +ve
    green to -ve coil
    have thick Black wire from tci switch to earth (this one im uncertain)
    have hall sensor plugged in
    have Brown to earth
    owned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
    Camden, Sydney
    I think black should be live.
    sydney/ cessnock
    Unhappy wirewing mad
    when i put that wire with the thick black sheath and brown inner to +ve the ingition lights comes on even with the ingition switched off.
    not sure whats going on thanks for the responce guys
    Camden, Sydney
    You probably have the wires to the coil on the opposite sides.
    syncro Guest
    Brown is always earth. Black is ignition +.(15)
    Don't worry about sheath as they are always black or grey.
    Quote Originally Posted by sydneymk1 View Post
    That black is definitely the earth and in probably long enough to get to the battery earth terminal.
    Best advice is to get the Haynes manual that covers the 16V wiring. It has a green cover and not red.
    Perth. WA
    Hope his helps,
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Camden, Sydney
    Looks like Gold roccodingo.
    sydney/ cessnock
    Smile black sheath brown was negitive
    thanks for the responce Brown wire black sheath was negitive..
    Got spark yeah!
    got a vw cabrio relay for the fuel pump got it wired sweet
    this project is finally coming together
