Results 1 to 8 of 8
Thread: 02a in mk2/1 which clutch cable to use?
    Jun 2006
    Hornsby
    hey guys, just wondering what cable you use?
    I know some peps use the auto adjusting Ibizia and others use the mk2 1.3cl cable any thoughts?
    cheers
    90 GTI Mk2 1.8t soon to be with GT28rs
    Jun 2006
    Orange NSW
    I use the auto adjusting cable in mine off the ibiza gti, they are a bit pricey but works a treat! I got mine off Loon.
    So the 020 didn't handle your 180+kw atw"s?
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Jun 2006
    Hornsby
    hey mate,
    Oh it did it is not broken, infact its in mint nick. The clutch is now slipping at 18 PSI so I thought that rather than using an 020 clutch I would upgrade the whole box and take advantage of a hardcore clutch and 18mm more of surface area. I am getting a 6 puck botton with sprung centre. so that I can smash it all day every day. PS i didnt machine my last flywheel. heheh cardinal sin.
    Jun 2006
    Hornsby
    mate u got the part number on that cable?
    tar
    part no. 6K2721335F on the cable, still trying to work out where the brackets goes if someone knows please chip in
    Jun 2006
    Hornsby
    mate the big bracket provides tension to the cable and bolts onto the 02a gear box mount. the other bracket just holds the cable out of the way of what ever was in the way in the seat.
    Quote Originally Posted by tommymac View Post
    thanks for that . i bought the whole lot together, in that case may not need the bracket. will see once i get the custom mount from uk
    Jun 2006
    Hornsby
    mk1? i still think you need the bracket as it provides the tension otherwise the cable may not work, ill have to get back to you on that as mine isnt in yet.
