Results 1 to 10 of 12
Thread: Some shifting technique concerns
    Jul 2013
    Caulfield, VIC
    Hello,
    I've been driving a manual for a year now and have been thinking about some technique related things.
    Firstly, when down-shifting to approach a turn or traffic lights, which would it wear the clutch less to quickly dump it, or to gradually lift your foot? And by quickly dump it I don't mean anything drastically fast.
    I'm not sure which would cause less wear because:
    Dropping it quickly means
    -More of a flinch of the whole car, as the clutch hooks up and the front dives when the engine comes up to speed
    -More pressure on all moving engine components
    -More pressure on the clutch friction surface at a larger speed difference between the plates
    -Less actual time that the friction surfaces has to rub against one another
    A slow lift
    -More time that you hear the engine come up to speed, and more time the clutch is rubbing
    -More time you're on the brakes, and the car isn't being slowed down by the engine
    -Less pressure on engine components
    -Leg seems to get more tired
    Second thing with my Skoda Octavia RS, and some other manuals I've driven:
    It seems like most gearboxes have a safeguard to prevent you shifting it to first from above say 15kmh. I noticed that when I'm coming down to first from a higher gear, its easier for me to clutch in, and put a bit of forward pressure on the gear knob towards first. Once I've reached the safe speed the knob automatically moves forward under my hand pressure, and off I go.
    However, some times when I do this I feel an obvious double click. Its quick fast, like a jolt through the gear knob. Whatever it is, it never feels good, and it doesn't always happen. When it does happen though, I don't like it. I just wonder what is actually happening here, and whether I should ditch this habit.
    If anyone has any other shifting technique concerns feel free to post them.
    Thanks
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    Jun 2011
    Sydney NSW
    The clutch is there to be used. The rate of engagement is to reduce overall stress on the drive line.
    The clutch is replaceable, the gearbox is not designed to be something you replace like a clutch. A sudden take up is going to stress the gearbox. It is like brakes. They are a wear element to do their job. You do not want to make it so that you take ages to engage the clutch. You can tell if you are doing it too quickly or too slowly.
    Quote Originally Posted by wai View Post
    I second the above comments, it's a replaceable item like brake pads. Not slipping the clutch from a standstill is going to be the biggest wear situation I reckon.
    The std clutch should last anywhere between 100-160000km in my eyes.
    One comment I have to make is about changing to first while still rolling. I have seen lots of flogged out MK1 gearboxes with dead syncros for first gear. The engine should have more than enough tq to pull away in second if the car moving at all.
    I'd rather slip the clutch a touch, than wear the gearbox.
    Oct 2012
    Or double de-clutch into 1st
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Quote Originally Posted by mb1907953 View Post
    We are well past the 1940s now you know. Even I don't remember them
    Nov 2013
    GoldenGrove SA
    Double de-clutch will both allow for an easier shift in to 1st and reduce damage to the synchro, yes it is old hat but matching engine revs to gear speed still works.
    Flash back to my first car EK holden with the grey 132 cu inch non synchro 1st gear did plenty of 2nd to 1st down shifts, needed to with the small drum breaks poor hydraulics and no power assistance
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by gazzmo View Post
    This. And it makes for smoother power transfer when pressing on meaning the car is less likely to misbehave on the downshift (important when hard on the brakes at the end of a straight). I double declutch with all downshifts out of habit and need to consciously downshift the 'normal' way. And it's a great feeling when you get it just right and the box shifts more smoothly and quickly than an upshift.
    I regularly shift into 1st at around 40kph.
    Resident grumpy old fart
    Jun 2011
    Sydney NSW
    The thing about double de-clutching on a box with synchromesh is that not everyone actually gets it just right and the synchro srill does its bit. To know you have it right, you have to do it in a box without synchro. Many non-synchro boxes are designed to literally crash change. Even many racing drivers don't actually get it right and heel/toe so that there is no sudden change in engine speed that can upset the car in heavy braking.
    Peregian Beach
    You don't need to double de-clutch. As a matter of course I always give the throttle a little blip when I down change and it doesn't take too muh practice to get the revs just right so that it slips staight into gear and you let the clutch out so that there is no shock or slipping of the clutch. My Bora 4mo has nearly 300,000 k's on it now and no sign of needing a new clutch.
    Oct 2010
    Melbourne, VIC
    Of course, the synchro normally "still does its bit" when double declutching with a normal box, hence my
    comment. The synchro "still does its bit" on the upshifts so you can feel a slight hesitation and resistance while the clutch is decelerated to match the gearbox input shaft revs and that is why you can engage faster when you match the revs really well on a double declutched downshift.
    And any non-synchro box is inherently "designed to literally crash change" as the lack of synchro means that the dogs used for engagement are much larger and hence, much stronger. The race drivers call them crash boxes for a reason (you crash on the upshift since no one is going to take the time to let the engine revs fall) but you still need to get the revs close on a downshift to be able to shift, else the dogs move past each other more quickly than you can force the engagement.
    And as for "heel/toe so that there is no sudden change in engine speed that can upset the car in heavy braking", isn't that exactly what I said with ?
    And it's easy to tell if you are able to "actually get it right" with a normal synchromesh gearbox (besides downshifting into first). Just try shifting without the clutch - if you know how to do it, you can drive around quite happily without using the clutch except when starting or stopping (not that I recommend it as you can damage the synchro if you try forcing the shift past the baulk rings when your revs aren't close to the being correct).
    I'm not saying any of this is required on the road but it is one of the joys of driving a manual (I was forced to learn with my first car since the syncro in 2nd was worn out)
