![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
gazzmo
Double de-clutch will both allow for an easier shift in to 1st and reduce damage to the synchro, yes it is old hat but matching engine revs to gear speed still works.
This. And it makes for smoother power transfer when pressing on meaning the car is less likely to misbehave on the downshift (important when hard on the brakes at the end of a straight). I double declutch with all downshifts out of habit and need to consciously downshift the 'normal' way. And it's a great feeling when you get it just right and the box shifts more smoothly and quickly than an upshift.
I regularly shift into 1st at around 40kph.
Resident grumpy old fart
