this is difficult, i'll tell you what i know
the most important thing is to get your crank - cam timing correct - otherwise without fail, you will have bent valves! it only takes a tooth.
theres a slot ground into the end of the camshaft which you may have locked against moving on the head. it only lines up one way so this should be easy to line up.
ofcourse turn engine to TDC. get it well lined up.
now, if you turned the engine with the head off, then you probably havent turned the injector pump, because you locked it into place with a bolt/ peice of tube first, didnt you?
if you did, this should all be fine to put back together. so, at tdc, the valves on cyls 1 and 4 should be shut.
if you have turned the pump somehow.... then i dont really know what you should do.... a diesel mechanic may know how to set the pump to the tdc #1 position.
theres a tractor manual that deals with the golf diesel engine which is very good.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
