1995 Volkswagen Golf III Cruise Control Wiring Information
Constant 12V+ Red Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake Red/Black Brake Switch
Tach Black/Red Or Green At Coil
VSS Wire White/Blue Driver's Firewall 3 Wire Connector from Transaxle
Pulses Per Mile 8000 PPM
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
