Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: were do i start with motorsport..
    Aug 2006
    Melbourne VIC
    Post up some pics mate...
    Oakleigh VIC
    Quote Originally Posted by [-Polo GTI-] View Post
    that caked on sound deadening has proved to be a bit of a b*tch to strip off...has anyone found an effective method of getting it off.
    Just did it this weekend. A few hours with a heat gun and a scraper did the trick.
    I reckon I pulled a lot more than 1.3Kg out of there! I'll have to weigh it all, mine had 2 layers in places, probably to hold the rust together!
    Pete
    Oakleigh VIC
    At some stage you're going to have to make the car track legal too.
    It takes a while to get your head around it but have a look at this http://www.camsmanual.com.au/
    You'll probably have a lot more questions after you get through that little lot.
    It's not as daunting as it first seems but you will need to be able to get your car to comply with it so it's useful to understand it.
    General requirements for cars and drivers covers most of the stuff you'll need to do.
    http://www.camsmanual.com.au/general.asp
    You'll get a hard copy of the manual when you apply for your licence.
    Pete
    Oct 2006
    Ive heard of ppl using dry ice to get rid of that sorta stuff but i havent done it myself. Just food for thought
    Perth. WA
    Quote Originally Posted by peedman View Post
    Yeah, I used dry ice, let it freeze the tar mats , then gently tap the underside with a soft hammer...then vacuum out the crap, wash down with thinners will remove the last of the adhesive, maybe even some of the factory primer as well...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
