I've been a bit tardy getting my entry together, but I'll be there too (in the type 1 class) in the mk1 cabby turbo diesel. ![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
Should have my forms emailed to you in the morning Chris.
On bonnet restraints - you can buy a nice little steel cable job that is heat-shrink covered and has a steel carabeena at one end and a d shackle at the other end (eBay!) which can easily be mounted with one end fixed to the top of the slam panel/radiator supplor through a hole ,and the other end clipped into the bonnet.
I fitted one to the cabby last year for this event and scrutineers were fine with it. All I had to do to fit it to the car was drill 2 8mm holes in places you will never notice
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
