Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: VW Nationals 2013 Supersprint May 25
  1. #21
    Feb 2008
    hey guys,
    since we are on topic of bonnet fastening.
    what ive got is a carbon fibre bonnet on my mk2, which has 2x separate bonnet pins on each end of the bonnet at the front, but the original locking mechanism has been taken out.
    Now, ive done a supersprint at eastern creek, passed scrutineering no dramas.
    will i have an issue at wakefield?
  2. #22
    Quote Originally Posted by russ83 View Post
    hey guys,
    That sounds fine - 2 x bonnet pins will suffice
  3. #23
    Mar 2011
    Wollongong
    Quote Originally Posted by Water Boy View Post
    Ahhhhh really this is new to me. My father runs in IP at state national/level and still runs an extinguisher.
    It came in a tech bulletin early last year. I cant find the actual bulletin (probably because the CAMS manual has been updated now) but its mentioned on the last page of this: http://docs.cams.com.au/Speed%20Read...EED%20READ.pdf
    Individual series could always insist on it I guess if it is published in their regs.
  4. #24
    Aug 2006
    Melbourne VIC
    Well my car started today after 3 years off the road. So finger crossed ill get all the other stuff sorted!
  5. #25
    Aug 2008
    Bondi, NSW
    I'll be there in my VR6.
    Snapped a shaft at Wakefield on Thursday but it will be all good to go for next month.
  6. #26
    Mar 2011
    Wollongong
    List of entries received so far, pretty even air vs water at the moment :
    Type 2 0-1600cc
    114, Justin Holden, Honda Civic
    Type 2 1601-2000cc
    28, Russell Sheffield, Golf GTI
    111, Jamie Clapham, Beetle
    Type 3 1601-2000cc
    13, Martin Fox, Beetle
    31, Troy Traeger, Beetle
    268, John Ladomatos, SuperBug
    Type 3 2001-3000cc
    8, Greg Mackie, Beetle
    Rene Felkl, Beetle
    Type 4 2001-3000cc
    54,Lloyd Davies,Audi S4(B5)
    88, Andrew Kemp, Mk3 Golf
    154,Peter Davies,Audi S4(B5)
    Type 5 0 - 2000cc
    258,Stephen Hooker, Jedi MkIV
    Type SV 2001-4000cc
    106, Jak Rizzo, Superbug
    303, Steve Carter, 1303 L Bug
    77, Gary Dower, Golf R
    11, Paul Zanello, J/S Buggy
    Steve Muller tba
    Greg McKinley tba
    Nathan Fellows tba
  7. #27
    Add me in - probably type SV from above by the look of it.
  8. #28
    On the bonnet restraints, the supplementary regulations are out:
    http://www.clubvw.org.au/assets/pdf/...intsupregs.pdf
    "15. Scrutineering Requirements.
    a) All vehicles are to be presented at scrutineering and must comply with Schedules A
    & B of the CAMS General Requirements for Automobiles (as specific in the CAMS
    Manual), including
    • A fire extinguisher to CAMS requirements and fitted within reach of the driver.
    • A blue triangle, 150mm on each side mounted to indicate the battery location.
    • A secondary method of securing the bonnet.
    • All forward facing glass lenses to be completely covered by a protective film.
    • All loose objects are to be removed from the car.
    • The battery is to be firmly clamped.
    • Vehicles that have been issued with a CAMS Log Book must present the Log
    Book at Registration and Scrutineering.
    b) Competition numbers are to be positioned on both sides of the vehicle, and must be of a
    contrasting colour to the surrounding bodywork. They must comply with the current CAMS
    regulations as to size etc
    c) Drivers and vehicles must be presented in a clean and tidy manner, completely ready
    for the track including the driver’s apparel and helmet. Any tyre or component changes to
    the vehicle after scrutineering must be approved by the Chief Scrutineer before the vehicle
    is taken onto the track.
    d) Any vehicle found to be leaking oil or fluids whilst competing will be suspended from the
    event until the Chief Scrutineer / Clerk of Course is satisfied that action has been taken to
    rectify the leak. Should there be a re-occurrence of the leak then the vehicle will be
    excluded from the remainder of the event.
    e) All vehicles must be fitted with towing hooks or a similar device both front & rear to allow
    for the speedy removal of a vehicle from a “sand trap” or removal from the circuit in the
    case of a mechanical failure.
    f) Fuel must be in accordance with Schedule G of the current CAMS Manual. "
    So if someone (Aaron?) can check with the scrutineers (not sure who) to clarify on the bonnet restraints. My car is already fitted with one, but I know what a hassle it was for all the late watercooled cars last couple of years!
  9. #29
    Dec 2012
    Sutherland Shire, Sydney
    I just submitted my entry also
    Is it possible to get my car number pre-assigned before the event? (24 or 42 would be good)
    I would like to spray it on the doors using plastic dip - should look smart and easy to remove afterwards
  10. #30
    Dec 2006
    Kilsyth, VIC
    Just realised that while I paid up a while back I sort of neglected to actually fill in the form :S
    Now it's done and will be posted as soon as I can get to an envelope.
