Hi James,
just picked mine up last weekend, needs a bit more work than anticipated but you get that with cars bought sight unseen, still it's a pretty sound base to work from.
'76 2 door fitted with a 2e 2l. Inj. and 5 speed gti box, has a manifold back large bore exhaust no cat, adj. cam wheel, cam specs unkown, pod filter. internals standard, plan to install: larger exhaust valves and port, increase comp. ratio, lighten / balance bottom end, then further down the track convert to Megasquirt management.
Chassis has bilstein shocks and stiffer/ lower springs and a whiteline front sway bar. Has an alloy half cage that needs replacing for circuit racing and harnesses that have almost expired, they may still be ok for hillclimbs ect.
great to here from another keen golfer.
Steve
'03 LT35
'89 Syncro Kombi
