Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: QLD - TimeAttack 2016
  1. #21
    Jul 2012
    Gold Coast, Qld
    If you get one, get blue; red's already taken.
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  2. #22
    Feb 2013
    Eatons Hill, Queensland
    My cut and paste skills are l337…
  3. #23
    May 2012
    LOL nice work K man.
    I've decided to run R compound only this year. It's Holy Grail time.
    Sean will u be running the Poli in the N/A Rotary class this year?
  4. #24
    Feb 2013
    Another request for suggestions. What about tow hooks.
    I remember being told the alloy tow hooks are rubbish because they bend under load. I'm not planning to leave the black stuff...but I just want to be sure that I can be towed if required.
    Alloy tow hook a la...
    QLD - TimeAttack 2016-165323_x600-jpg
    OR
    Is the factory cast iron tows the better option.
    QLD - TimeAttack 2016-s-l1600-jpg
    Anything better to consider?
  5. #25
    May 2012
    I can definitely tell u that alloy tow hooks do bend under load but they are lighter. If you don't plan on leaving the black stuff both work perfectly well. I bought a ribbon style for this year, hopefully I won't need it but having said that, you could just run out of fuel and need a pull back to the pits...right machine?
  6. #26
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by An7on View Post
    OR
    Unless weight or looks concern you, I don't think there's anything better than the factory tow hooks. My car came with one and I bought an extra one, so I can screw in to both front and rear. I've used them, too, a couple of times without issue.
  7. #27
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by grandturismo View Post
    Exactly. If you like to use every drop of fuel in the tank and go for those PB's with the lightest possible car, you definitely need a tow hook!
  8. #28
    Feb 2013
    I think a second OEM hook will be the go.
    I think I'll hit up the wreckers.
  9. #29
    Jan 2011
    Brisbane - QLD
    saw one on ebay at one point for $20 only
    MINI Cooper S Clubman - FWD
  10. #30
    Jan 2009
    I think it's C3, performance class, same as you perhaps. I emailed Paul last week about the categorizing of last year having me in the NA class. The class and points won't matter to me, going to be a tail ender anyhow. Unless there's a Poli class, should do well in that.
    My holy grail would be cracking into the 61s, not sure that's realistic. Mid 62 I'll be chuffed.
    Daily: 2010 VW Jetta Highline
