It was a very eventful weekend to say the least. Great videos Nat.
Here's s pic of my A050 that put an abrupt halt to my AM session.
so today was another session of attacking time...
did not do any PB as i went easy on the eastern loop. there was an oil spill from a mx5 on the eastern loop section of the track in the session prior to mine. i had a small slip moment on the first lap, so subsequently i went easy.
here are of the best times of the day:
before track, oil level just under max, after 30 hot laps, still just under max. conclusion: no oil use
Current mods:
- Bluefin Stg 1 + GFB DV
- H&R sport springs + Superpro 24mm RSB + Ground Control front camber mounts + OEM DCC in sport mode
- Unibrace UB
- Advan AD08R 235 40 18 on Rays VR-G2 18x8 +50
- Front QFM A1RM brake pads and Penrite racing brake fluid, with the rest brake components all stock
MINI Cooper S Clubman - FWD
I can't believe that's real, Al. Good job staying on the track, Nat![]()
Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
I've just sent you all a PM.
The 86/BRZ club are holding sprints next Saturday at QR and have a few spots free if you are interested.
Thanks Clay![]()
Holy moly Al…that is some serious tyre carnige, 10/10 for staying on the black stuff after a blow-out like that.
Jesus...can't wait for mine to blow.
