i would have popped down to watch but a friend is leaving to go back to the USA on sat
Saturday April 26th 2008 Circuit Familiarisation
http://www.piarc.com.au/
http://www.piarc.com.au/files/April%...0CF%20Regs.pdf
Saturday
Has been allotted as a circuit familiarisation/driver training day where advice from racing drivers will be available for
those who require it, or competitors may go out an learn the circuit on their own. Competitors will be allowed a
substantial time on the track (We would expect approximately 1 hour of track time in the form of a number of 15-30
minute sessions). This day may also include passenger ride sessions. The entry fee for Saturday is $150.00 (Entries
before 19/04/08 $135.00).
Should be a fun day, I'm hoping to learn a lot from it.
Anyone else coming along to drive or watch?
Pete
what does that mean in real terms peter? im guessing id need to put in a fire extinguisher and bonnet clips to do it? plus pay PIARC and Cams license
currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
Full text is here http://www.camsmanual.com.au/zip-fil...anual_Q208.zipCompeting cars are required to comply with section 6, Schedule A & Schedule B of the 2008 CAMS Manual. The
minimum requirements for road cars include:
- Cars must be in a presentable and roadworthy condition.
- Minimum of a three-point harness system.
Fire extinguisher firmly fixed in car while competing. Fire Extinguisher comply with Schedule H of the CAMS
Manual. NOTE: BCF/Halon extinguishers are illegal.
- All vehicles, must be fitted with two separate fastening systems on any front openingpanel.
- Any cameras must be mounted in accordance with Schedule A and the relevant CAMS Technical
document..
- Fuel must be in accordance with Schedule G of the CAMS Manual.
So to translate.
Schedule A requirements.
Any stock Golf would comply.
Schedule B requirements
Again Stock Golf is mostly Ok but this section requires
Fire extinguisher
Bonnet restraints.
2 L Catch can if breathers are vented to atmosphere
Battery triangle etc
So to really make it simple.
If you're starting off with a roadworthy stock car you would also need
A helmet
Fire resistant full length clothes (Woolen Jumper/jeans) closed shoes.
Fire extinguisher (Autobarn $30)
Bonnet restraints (Doesn't have to be fancy a leather belt passes.)
Battery sticker, (I'll give you one if you want to come and play!or revolution racegear)
Money -
$150 for PIARC event entry.
$95 for your CAMS L2S License (Can be purchased on the day)
$40 To join Piarc for the day (You have to be a member of a CAMS affiliated club in order to get a CAMS license. If you're already a member of VWCV for example you already qualify and don't need to pay this, bring your membership card.)
CAVEAT - Check with someone who's done this before. I'm pretty sure I haven't forgotten anything but it's not my fault if the scrutineers won't let you on the track.
I'm sure someone will pop up and fill in any blanks.
Pete
I forgot to mention , your lap/sash seatbelt qualifies as a 3 point harness for this if I'm reading the rule book right.
So long as
The retractor works
There's no frays
It was made after 1978 and complies with ADRs
Pete
I'm interested in coming down saturday arvo. knock off work at one. will there be much action at 2:30-3:00 though??
Hard to say ,
The event finishes at 5:00. I think the practice runs are slotted in between the Karts.
The cars run in groups I think you'll get to see my group run within that timeframe at least once.
Pete
Cool, so about $280 for the day. thats not too bad i guess. i think its $220 for Steve Brouggys Bike days last tiime i checked. Did PI at easter time on a rental bike it would be cool to do a comparison in the car. cant do this saturday now though, got bbq at 12 with the outlaws.
When I went
Fire extinguisher = must be date stamped
Metal valve caps on wheels
approved helmet
cams licence
Battery sticker
bonnet tie
Think that is about it from memory. Enjoy guys
is there still spots avail?
i might come down...
MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
