Results 11 to 20 of 28
Thread: Phillip Island Circuit Firmilisation (Saturday 15th August)
    Point Cook, Vic
    Quote Originally Posted by velly_16v_cab View Post
    do you need to do that to get the license?
    If youre interested in VW club membership then it works out cheaper.
    FOLLOW US ON FACEBOOK
    Aug 2006
    Melbourne VIC
    Join a club like PIARC (Who is running the day)
    Boronia VIC
    Yep, you've got to be a member of a CAMS affiliated club to be eligible for a CAMS license.
    VWCV and PIARC are the two clubs that spring to mind in Vic.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    I might be in NZ that weekend. I better check
    Aug 2006
    Melbourne VIC
    First post updated!
    better add
    CAMS S2 license to the list bro
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    May 2009
    I'm probably going to compete in the group5 sprints on the Sunday instead.
    Pete
    Peter is that on @ Philip island as well? Ran the car @ Sandow 2 weeks ago and loved it.
    Inlet manifold machined - done
    all new gaskets - done
    new CV's - done.
    semi slicks working a treat.
    think a brake up grade is on the way but...
    cheers
    Boronia VIC
    Yep.
    Regs are over at the PIARC site.
    http://www.piarc.com.au/files/August...int%20Regs.pdf
    These are the regs for both the familiarisation on Saturday and the Group5 Sprints on Sunday.
    Pete
    7? MK1 Caddy
    12 Amarok
    If you Join philip island you don't ned to join for the whole year just pay the remainder and you can then get a cams S2.
    What about metal valve caps I'm sure you needed these no?
    Boronia VIC
    Quote Originally Posted by evorobin View Post
    It's all in the book.
    http://www.camsmanual.com.au/
    Specifically, Schedule E requirement 6.
    http://www.camsmanual.com.au/pdf/10_...ule_E_Q309.pdf
    6. VALVE CAPS
    Each tyre valve shall be fitted with a cap which effectively prevents leakage in use.
    Typically plastic caps are not regarded as capable of preventing leakage.
    I imagine the rationale to be that the cap needs to be a backup seal if the valve itself fails.
    Pete
    7? MK1 Caddy
    12 Amarok
