Join a club like PIARC (Who is running the day)
Yep, you've got to be a member of a CAMS affiliated club to be eligible for a CAMS license.
VWCV and PIARC are the two clubs that spring to mind in Vic.
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
I might be in NZ that weekend. I better check
First post updated!
Yep.
Regs are over at the PIARC site.
http://www.piarc.com.au/files/August...int%20Regs.pdf
These are the regs for both the familiarisation on Saturday and the Group5 Sprints on Sunday.
Pete
7? MK1 Caddy
12 Amarok
If you Join philip island you don't ned to join for the whole year just pay the remainder and you can then get a cams S2.
What about metal valve caps I'm sure you needed these no?
It's all in the book.
http://www.camsmanual.com.au/
Specifically, Schedule E requirement 6.
http://www.camsmanual.com.au/pdf/10_...ule_E_Q309.pdf
Typically plastic caps are not regarded as capable of preventing leakage.6. VALVE CAPS
Each tyre valve shall be fitted with a cap which effectively prevents leakage in use.
I imagine the rationale to be that the cap needs to be a backup seal if the valve itself fails.
Pete
7? MK1 Caddy
12 Amarok
