Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Fire Extinguisher in MkIV
    Apr 2008
    Canberra
    Hey, i've got my 1st track day comming up and i was wondering if anyone has some tips on where to secure the fire extinguisher. i dont really want to be drilling holes that are really obvious when the extinguisher isnt there.
    Surely someone has had to do this before.
    ~~~~____~~~~~~~~~_\_____
    ~~~ /_|__\__~~~~~~ / //__|__\___
    ____( )|__( ) ]_MKI ___[(' )__|___( ) ]_MKIV__
    Jan 2007
    Both of mine are in front of each seat so in reach of the driver and co driver when they are harnessed in their seats as per the CAMS regulations.
    Wherever you decide to put them make sure they are secure (IE not just cable tied in) as the last thing you want is a 5KG metal missle flying around the cockpit if you have a big off. Pictures below and more general pictures of them in the interior can be seen in my gallery here
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Apr 2008
    Canberra
    OK this looks reasonable. So did you just drill through the floor and put bolts through?
    Im not that keen on drilling holes throught the floor, but if thats the only way i will just have to man up and start drilling.
    Oct 2006
    Quote Originally Posted by quozl View Post
    Al, How can you reach the floor when harnessed in?
    Mar 2007
    sydney
    put in in the cup holder there is room for 2 of them lol
    mk4 the mods begin for round 2 hahahha
    Quote Originally Posted by Flaps View Post
    I think if you needed the extinguisher, you might have undone your harnesses first
    C
    It's been a while...
    Boronia VIC
    Read the manual!
    http://www.camsmanual.com.au/pdf/gen...ule_H_Q208.pdf
    3. SPEED EVENTS, RACES AND DRIFTING
    Each automobile of the 2nd, 3rd, 4th, 5th and 6th Categories in a speed event or race must be equipped with a fire
    extinguisher which complies with the following conditions and is properly fitted at a suitable location:
    (i) it must comply with Australian Standard 1841 (save that extinguishers which meet AS1841.2 are not permitted).
    Note that Halon extinguishers (1201 or 1311, including BCF) are not permitted under civil legislation;
    (ii) it must be of at least 900g capacity;
    (iii) it must remain restrained under an acceleration of 25G;
    (iv) it must be capable of removal by the driver without the aid of tools.
    The fitment of an “on-board” extinguishing system homologated by the FIA shall be acceptable as an alternative
    to the fitment of a separate extinguisher.
    Pete
    Apr 2008
    Canberra
    I have been through the manual and it tells me what i should have, but not how to put it/where to put it in the car.
    It looks like i may just have to screw it to the floor somewhere. I was just hoping that someone else had done this to their streetcar already and could give me some tips. Thanks Quozl for the pics, i think i will try the same.
    Boronia VIC
    Passenger side footwell.
    Captive end of bracket forwards.
    Mounted through floor with grade 8.8 M6 bolts and mudguard washers either side of bracket and floorpan.
    Loctite on bolts.
    Gauge against tunnel to prevent passenger from damaging it .
    Passed CAMS Scrutineering @ Phillip Island April 2008
    Australian Standards approved extinguisher purchased from Autobarn
    Packaging also indicates CAMS approval.
    Scrutineers will check fixing, condition, clamps, pressure, safetys and dates.
    Read the manual!
    Pete
    No mention of a date stamp. Most scrutineers will want a stamp no?
