Results 1 to 9 of 9
Thread: does anyone know who does good cages for mk1
    hey.
    i am building a golf mk1 racing i need to get a cage in it but i dont really want to spend over 2000.
    cheers
    Jun 2006
    Orange NSW
    Quote Originally Posted by 16v_rabbit View Post
    hey.
    cheers
    Full or half cage? I'm going to do a half cage myself for my mk1.
    There's a number of companies that will build you a cage and when you get it, you cut it where you need to to put it in the car then re weld it. Bond roll bars will do that i know..
    TassieGTi Guest
    Go the "BOND "one.
    We have used 3 of theirs now in past projects.
    Jun 2006
    Orange NSW
    Quote Originally Posted by TassieGTi View Post
    Go the "BOND "one.
    Do they do them for mk1's? What sort of money did it cost you for what sort of cage if you don't mind me asking?
    Aug 2006
    Melbourne VIC
    Mate where u located... Remeber if u are building the car up for race or rally use the cage must be Cams approved...
    Check out www.cams.com.au for more info there is heaps of different deisgns... Got to take into accounts chrom or mild steel? What hoop and how many bars, where the X's are and what side intrusions bars...
    It a lot of work to get right... Too many bars and it will way a tone not enough and a hit will be bad news...
    Boronia VIC
    Try these guys, I had a harness bar done and their work was excellent.
    http://www.browndavis.com.au/
    Pete
    Apr 2006
    Hobart,Tas
    I got a Trik bolt in full cage years ago. Got mucked around a little bit but it fitted perfectly and the intrusion bars werent that hard to get over when getting in or out of my Mk1.
    Cost was about $1600 and they are in Vic.
    Good luck with it,
    Andrew
    Jun 2006
    Orange NSW
    Quote Originally Posted by gtimk5 View Post
    Good luck with it,
    Andrew
    For that kinda money it isn't worth doing it yourself.. How long ago did you get that done Andrew?
    Apr 2006
    Hobart,Tas
    That was about 6 years ago I think. What he does is source a model in Vic and builds the cage to suit that. Then he sent it over with the pipies a little bit longer so you trim them to the correct length. That way YOU become the manufacturer of the cage when it comes to getting it certified and registered with CAMS. Also, if by some chance that in competition you suffer a shunt, then you can unbolt it and fit it to your spare bodyshell!!!! I had 2 spares plus guards and doors ect all painted up ready in case. Came in handy after T boningt someone at Symmons. I competed in the MG club annual hillclimb 2 weeks later and finished on top.
    Andrew
