The oil pressure warning light should go off with pressure between 1.2 and 1.6 BAR. 2.7-4.5 BAR is normal at 80 degrees. At higher engine speeds pressure must not exceed 7BAR. Quoted from the BJX engine manual. There's a 12 BAR pressure relief in the oil pump.
