Results 1 to 10 of 13
Thread: Acceptable oil pressure and oil temperature at track days??
    Jan 2011
    Gold Coast, QLD
    Hi everyone,
    I am thinking about purchasing some gauges for my car to make sure I am not causing premature engine/turbo wear at track days.
    What are acceptable limits in regards to..
    1. Oil temperature
    2. Oil pressure
    For instance what is the maximum oil temperature recommended for 5w-30w full synthetic?
    I found this graph on the nulon oil blog. But I am unsure how accurate it is, and it still doesn't identity a max limit. It does look like 75 degrees is where the oil reaches minimum viscosity.
    [IMG] http://blog.nulon.com.au/uploads/2013/10/Temp-graph.jpg[ /IMG]
    Also in regards to oil pressure what is acceptable? Should the pressure be constant at all times while the car is in motion on the track? I'm assuming when idling the pressure is a lot less?
    Does anyone have any knowledge in regards to this topic?
    Thanks.
    Dec 2012
    Sutherland Shire, Sydney
    Your MFD has oil temperature
    It can be anywhere between 95 and 110 deg
    On a track day you will see it reach 115~118 deg
    I would not be keen to see it over ~120 deg
    Oil pressure can be high when cold and then reduce
    Oil pressure increases and decreases with RPM
    At idle you would want more than 12psi
    Start up could see 80+ psi
    Normal running could be around 45~65 psi
    Quote Originally Posted by Martin View Post
    Oil temp isn't available on a MK4 in Australia that I have seen. It would normally follow the water temp most of the time.
    Oil pressure needs to be over 21PSI to switch off the light when you start. Then there's a requirement for 40PSi at 2000 revs IIRC. I can look that up if you really need to know it. 80PSI should be an absolute maximum pressure, the relief valve should blow before that.
    Oil pressure is related to engine speed so will constantly vary.
    I'd definitely be keen to have the oil level on the top mark, rather than the bottom at the track. I doubt you'll have any problems in a basically std car with the std turbo.
    The Squib bumped the water temp over 90 at QR last weekend, that's the first time I have seen that. Longer straights and a full 30 minutes probably contributed. He might need some cooling attention in the near future......
    brisbane
    Are you sure it's a boy, have you checked?
    good info mate, something to keep an eye on at the track...
    Jan 2011
    Gold Coast, QLD
    OK that is good to know.
    A large majority of mk4s do not have the mfd. The oil pressure/temp gauge had to be plumbed into a blank port near the oil filter.
    Sprint sessions are usually 15-20 mins anyway. So not too long.
    I find water temps are rock solid 90 degrees all the time.
    I always open my bonnet in the pits and let the engine run to cool down the turbo.
    Gav if you could find out the specific details that would be great. When you find time of course. Where are you retrieving that info?
    I'll give the gauges a rethink.
    Dec 2009
    Kew, VIC
    I also found that, once warmed up, VW water temps are 90 degrees all the time — until I fitted an external device, when I found they fluctuate quite a lot, but it just doesn't show on the dash unit, which appears to be not much more accurate than a warning light.
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by Idle View Post
    How much did it fluctuate for you? I remember logging coolant temp through vagcom and it really didn't fluctuate more than 1 degree.
    Oct 2013
    They do this on purpose so they dont have every man and their dog coming into the dealership complaining about fluctuating guages!
    The guages are designed to sit in the sweet spot and not move untill necessary. As you say they are more of a warning light as thats all you need on a road car but people think extra guages on the dash are fancy so they put them in for piece of mind.
    this message thrown at you from the window of my flying Golf!
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
    Dec 2009
    Kew, VIC
    This was a Mk6 TDI103, the device was AutoPolar FIS, and the variation was, if memory serves me right, about 10 degrees — I've seen as high as 98C and the gauge still sat on 90.
    Still have the Autopolar, but the Mk 6 is gone.
    So far there's no sign of the device working on Mk 7 TDI110 — I suspect it never will.
    Quote Originally Posted by Sirocco20348 View Post
    I have a PDF of the VW manual for the Polo GTI. The guts of the motor are the same. You can realistically expect 10PSI per 1000 revs as a minimum closer to 15 in reality.
    I will dig in teh manual tomorrow.
