Page 25 of 63 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 630
Thread: 1/4 Mile Times
  1. #241
    Jul 2010
    St Ives, NSW
    Quote Originally Posted by adzy View Post
    Jesus! Well done ZB!! Recode is the only difference, did you have a dyno done after the tune? That is very impressive... and be carefull of the stock clutches launching at that rpm mate.. yikes! Come on Fab, get on it bro dont forget heathcote, will get plenty more runs there and the surface is maintained better than calder, way better traction.
    The difference is in both the new DP and the cooler weather. Unless Mark loaded another tune without telling me the tune that is on there at the moment is the same one that I ran the first time at WSID (it was loaded the same day) and also the same one that I ran at the dyno day. On the dyno at TurboXS it makes 201kw at the wheels vs 181kw with the APR DP. You may have seen the back and forth between Guy and me in the tuning thread about whether the different DP can really make that much difference. Time slip says it does because there is no way 10 degrees cooler air is going to make that much otherwise Ferret would have been even quicker than me.
    Golf R 5 door, DSG, EVOMS CAI, TXS DP, Recode Tune.
  2. #242
    Jul 2010
    St Ives, NSW
    Quote Originally Posted by Corey_R View Post
    Surfaces can obviously change with the weather conditions. Some surfaces can have more grip during the day, some during the night. Different compound tyres can also react differently, and different tyres can react differently to the previous tyres rubber laid down. So you could both have been right for your given days/nights that you were at each track
    Exactly. Ferret was at WSID last week and running 25psi tyre pressure was having traction problems. I think it was the first meeting there since they resurfaced the track. They had a race meet on the weekend so there was plenty of rubber put down and last night I was running road pressures and had no issues.
  3. #243
    Aug 2009
    Melbourne - West
    True, I'm just going by experiences with both tracks over the last 10 years that myself and mates have had. Heathcote was generally maintained at a higher standard (mainly the 60' area) where as calder was a very shiny, slick, slippery surface which would get covered in oil quiete often due to the tardy marshaling, the lower temp down melbourne would be a factor also.
    Depends on the day though I guess.
    Again... so good to see a couple of R's into the 12's now
    APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
  4. #244
    Quote Originally Posted by zbeasty View Post
    Hi Michael,
    Its the same file I was too lazy to change it as we are going to Autotech the beast soon anyway. There were more files earlier on pre dyno day that you might not have been aware of thats all.
    I feel for your DSG clutch pack
  5. #245
    Apr 2009
    Good job!!
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
  6. #246
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by parso_rex View Post
    Hey parso, do you think that it's possible that something you've done in your tune has allowed zbeasty to exceed the VW limit of 3000rpm using LC?
  7. #247
  8. #248
    Apr 2009
    Many things are possible
    You sir may become very rich haha if this helps people avoid a DSG flash haha
  9. #249
    Apr 2010
    Melbourne, Australia
    LOL........love your work Mark
  10. #250
    Jul 2010
    St Ives, NSW
    Quote Originally Posted by DeanCorp View Post
    You still need the DSG flash if you want faster shifts and higher clamping pressures not that I'm complaining about my new found launch capabilites.
