Good time Fab....
12.714 @ 106.13mph, 1.926 60ft, MK6 Golf R 3dr DSG, GIAC Extreme Tune/APR Hardware, Kumho ku36's @ 40psi, Fab_R
Sorry guys I will fix the format when I get home.
Just at heathcote after completing my 2nd run.
I'm right lane.
Running the GIAC Extreme tune.
Tyres 40psi
Good time Fab....
60' time still looks a little off. What rpm are you launching at? Given you have the HPA DSG tune you might want to try about 4000 or even up to 4500. If you have traction problems lauching at those revs you might want to drop your tyre pressures as well. Assume you're still running the 18's with the Kuhmo's and haven't put the 19's back on. If so try dropping them to 36psi.
Golf R 5 door, DSG, EVOMS CAI, TXS DP, Recode Tune.
Ooops... not stock tyres... duh, how could I forget the myriad of wheels you've been through! hehehe. Corrected my post.
Just ran this woohoo!!!!!!
12.467 @ 105.88mph, 1.8530 60ft, MK6 Golf R 3dr DSG, GIAC Extreme Tune/APR Hardware, Kumho ku36's @ 32psi, Fab_R
Winning!!!!!!! GIAC FTW!!!!!! suck on that APR f***kers!!!!! Fabby is smashin it!!!!
I told you the grass is greener on this side! Welcome to the dark side!!!
