Results 1 to 4 of 4
Thread: Wiper Arms?
    May 2010
    Melbourne, Victoria, Australia
    Question Wiper Arms?
    Hay all i just bought new wiper blades but thought i might as well get new/newer wiper arms as the left ones paint is corroding and is now half silver so if anyone knows where i can get a pair of black wiper arms for a 1995 SEAT Cordoba glx 1.8 please reply. Thanks
    Sep 2010
    Melbourne, Victoria
    If the entire assembly is corroding then I guess you would have to try a wrecker; Seat Cordoba '95 should be similar to the Golf/Bora/Vento generation of VW's.
    If it's just the wiper blade holder/arm part of the wiper assembly (not even sure what you call that), then might I suggest upgrading to Bosch Aero Twin wipers - they will not only do a much better job, but will also last alot longer and renew the appearance of the car. Pricey at first, but definitely worth it in the long run.
    There definitely should be one available for your car - if you take a close look at the arm clipping mechanism, as well as measuring the length of the blades, you should be able to find a compatible Bosch Aero Twin wiper for it.
    May 2010
    Yea i bought the bosch aero wiper things..and yea its the actual wiper arm bit that attaches to the car...well maybe ill check the wreckers then...thanks
    Jan 2006
    Lowood Qld
    I have a set here ..nice
    posted $32? due to odd size
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
