Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Window regulator!!!!!!
    Jan 2006
    Lowood Qld
    like the wire has come off the mechs
    due to worn or cracked palstic guides
    best repl whole mech unit
    german - english translations esp vw documents!!
    Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
    Camden, Sydney
    Quote Originally Posted by crazyazz View Post
    I havent taken the door trim off to look , but my driverside window doesnt move. I can here the motor working and it sounds like the other working window. What does this issue sound like? 99 Mk2 ibiza Gti
    You may be able to do the cable tie fix on this one.
    Basically, take off the door trim and remove the plastic weatherproof cover.
    THen use the switch to wind the window down half way.
    You will either see lots of tangled wire, or the mechanism will move but not the window.
    If it is the latter, remove the 5 10 mm bolts and undoo the electrical 2 pin connector.
    Also detach the window from the plastic slider another 2 10 mm bolts.
    Take the regulator and motor out of the door.
    Each of the two guides have a cable with a metal knob moving up and down them.
    Get the 2 plastic sliders which have an L shaped cross section and can be clipped onto the rails.
    You will see the locating position on the back of the plastic that the knob fits into.
    Clip the plastic slider over the metal wire and knob.
    When it is located, sneak a skinny cable tie behind the wire and throught the plastic slider to hold it in place instead of the broken clips.
    Do both sides.
    I usually plug em in before install and check they move.
    If its all good, put back in and locate window in plastic clip. I usually do the bolts up looely and jiggle the window as it goes up until it finds a happy spot, then tighten. Also grease the rubbers for non stick and smoother operation.
    Then reassemble door and enjoy the fresh ait.
    If this doesn`t work, call Camden GTI 02 46273072 for a replacement unit.
    Good Luck
    Vic
    Thanks Golf Loon, that is one of the most informative posts I have ever read. Will give it a go on the weekend.
    Have the door skin off now. Its looks like a mess in there, someone has tried pretty hard to destroy the RH front bracket, motor area. Will take some photos, as to better illustrate what I will need to fix it.
    Vic
    Hi guys, here is a picture of the window regulator. It seems the rearward section of the window is attached and will go up and down via the switch. Now the front forward section (pictured) appears to have pieces missing that would attach the window to what I guess is the runner. This white plastic runner (circled red) goes up and down when the switch is activated. I also found the black plastic piece sitting in the bottom of the door. Its all new to me , never have looked at window regulator before
    1999 MKII Seat Ibiza Cupra Sport
    2000 Audi TT Quattro
    2000 Audi B5 S4
    Camden, Sydney
    I have no idea what that black thing is mate. Maybe something used to hold the window??
    The reg you have is rooted. The loop of wire in view in the second pic means something is badly smashed. Wire will be all tangled round the spool and the reg is a chuck out.
    Sorry to be the bearer of bad news.
    Vic
    ok , so how much to fix?
    2000 Audi B5 S4
    Vic
    Hi guys,
    I have taken the window regulator out. It seems the cable has snapped and the white plastic clip is broken. Is there anything else missing? As I may try a repair kit from ebay before I finally cave and spend a couple of hundred on a complete replacement
    2000 Audi B5 S4
