Results 1 to 7 of 7
Thread: Toledo starts, but won't rev!
    Plenty of petrol in the tank? Decent plugs, rotor arm and cap. These would be where I looked first as they are cheap.
    After that I would be investigating the throttle position sensor on the throttle body. This is a simple variable resistor, over time the wiper and tracks get all dirty.
    if you are any good with a multimeter you could look at it and work out if they are OK or not.
    Also in the TPS is a closed throttle switch, if this is stuck in the closed position, the engine won't rev as it is in conflict with the output of the position part of the sensor.
    Gosford Central Coast NSW
    throttle cable?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Sep 2005
    Wellington, South Australia
    Thumbs up
    Thanks guys! So speedy!!
    Guess there's not so much to do when it's raining (at last!).
    Throttle cable is ok butterfly is opening, will check out those pesky switches/rheostats
    Thanks again,
    Chris
    Whoever dies with the most toys, wins.....
    Camden, Sydney
    Does it start for 4 seconds then die?
    Coded chip in the key? Try turning the key over and try again, or try another key if you have one.
    Matt
    Sep 2005
    Smile
    Thanks Matt,
    Toledo built 12/94 so no coded key.
    It WAS running sort-of-OK before but will not run over 100rpm no matter what.
    I have removed TB to check out throttle closed switch which seems OK.
    Is there supposed to be a full-throttle switch contained within this?
    There are three terminals in the switch.
    Thanks guys.
    Chris.
    Camden, Sydney
    Timing Out, or Dissy Cap or Rotor Cracked?
