Results 1 to 3 of 3
Thread: Toledo Fuel Rail
    Sep 2007
    melbourne. victoria
    Toledo Fuel Rail
    Hey guys
    i had a strong sense of petrol a couple of days ago and when i popped the hood seems like there is a tiny crack at the elbow of the fuel rail and when started up theres drops of petrol coming out of it when its running. i have a vwpart # 037 133 313 AM , any ideas where i might be able to source a new fuel rail or any repair ideas??
    96 seat toledo 16v (ABF)
    Camden, Sydney
    Is the crack where the clip pushes onto the rail?
    If its not right next to the rail, you could slide on some efi hose and use a clamp instead of the factory clip.
    I probably have a s/h fuel rail if you get stuck, the ABF ones are different to almost everything
    bardon
    1995 Toldeo ABF fuel rail connector - Cant find one anywhere.
    Yeah, Im after one of these too, it's a male o-ring based fitting that breaks easily and I need to find a suitable fix or replacement. I am considering tapping a brass fitting into the rail but it's my last option.
    The male insert on the fuel line cracked so I sleeved it with an piece of antenna of the correct diameter and glued it back together, Im concerned that if I attempt to remove it, it will break again and Im left dead in the water.
    Any advice?
