Results 1 to 10 of 11
Thread: Strange Intermittent Idle Problem
    Nov 2007
    Melbourne, Victoria
    Hey guys I have a '96 Ibiza GTI and have noticed recently I'm getting a strange idle problem. I'll be sitting at the lights and the tacho starts jumping, and the idle becomes rough (like the engines trying to stall itself) and then moments later it goes away. I run the girl on 95 octane, and are currently running some injector cleaner through it to see if it fixes the problem.
    I also have a cracked crankcase breather hose.
    I see you recomend Magnatec Loon? Oh and BTW, im guilty as well, the car has 173k's on the clock and i dont rev her much past 3500. I feel like im gona break the poor thing.. I think she might have to see 5k tomorrow, as they do like to rev.
    Lastly, the airbag light has been on for a while.. I think its the clockspring so im told. Do you have any spares lying around Matt?
    Thanks guys
    David
    1996 SEAT Ibiza GTI
    Camden, Sydney
    I have clocksprings mate, no worries.
    Id be putting in some 98 octane, checking the timing and going for a fang.
    Also clean the ISV valve round tube thing with a couple of pipes and a wiring plug on top of the rocker cover. That can affect the idle.
    Nov 2007
    Melbourne, Victoria
    ok ill give that a shot tomorrow.. what are we looking at for a new clockspring?
    1996 SEAT Ibiza GTI
    Camden, Sydney
    Quote Originally Posted by Kirbz252 View Post
    $120. Free Postage
    Maitland, NSW
    i have this same problem only i only put 98 in my tolly.. and i "occasionally" rise above the 3500 revs
    i still get the intermittent start with only 3 cyls too. tried reseating the plugs but thats about as far as my knowledge goes with it..
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
    Camden, Sydney
    Quote Originally Posted by Rednut View Post
    Is it blowing smoke at this time? Might be the blue choke control sensor making it run rich till its warm. Very common and similar symptoms to what you are describing.
    Matt
    Maitland, NSW
    nah no smoke.. the closest thing is the steam from the exhaust on 'camden' mornings
    Aug 2007
    Guys clean the ISV valve . I soak it in petrol or shellite. The thing gets gummed up with carbon.
    Jmac
    Alba European
    Blackburn South, Victoria
    I have the same issue now, after the cylinder head was pressure tested (as i had a disappearing water problem), new water pump and newish injectors courtesy of Golf Loon (cleaned and tested). The idle seems rough, even though the rpm needle remains constant. And when i clutch in to stop, the rpm drops to almost stall before recovering (it also has stalled a few times as well). Will cleaning the ISV valve help? Also no smoke or oil leaks..thank god
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
    Maitland, NSW
    what and where is the isv valve?
    loon, would i be capable of doing this or should i get my mechanic to do it while he replaces one of the radiator tubes?(leaking problem)
