Results 1 to 10 of 17
Thread: Some Q's about my new Ibiza
    Aug 2007
    Hi all,
    I've recently bought a very nice 95 Ibiza Gti that I'm lovin to bits right now!
    here are a few things I thought I'd ask for advice on before doing:
    1. The previous owner disabled the central locking for whatever reason. he swore up and down that there is nothing more i just need to get it enabled again. so if you were going to disable the central locking how would you do it? and therefore is it something I can easily undo myself? is it a matter of plugging a cable back in to the electrical system (and where do I find it if it is) or is it more complicated and I should take it to my local VW mechanic (or auto electrician) to get fixed?
    2. You know that black strip on the back of the gti that has 'Ibiza' and 'Gti' written on it. well its not real black anymore. I think water gets in there (or condensation) and it discoloured. I think if you remove the black 'S' badge I could then pick off the plastic and get to the black strip - but what do I do then? replace it or can you re-colour it. or even better would it be simply a matter of a good clean?
    Thanks all!
    95 SEAT Ibiza GTi
    Hottunning Coilovers
    Aug 2007
    Mate should be nothing complicated, what is the locking doing? does any of the doors work? The pump for your locking is at the rear, from memory pass rear near the tail lamp cluster, never heard of disabling it?? They had problems with door lock paddles breaking. Try locking it from the passenger door mate it should work from there. Let me know mate
    Alba European
    Aug 2007
    Um, all the doors open with the key only - meaning I can unlock the driver, passenger and boot with the key individually. The fuel gate is always open - but it should be linked to the central locking. I'll have a look in the boot for the pump... what does it look like?
    Update! found the pump, and yes it was "disabled" meaning the power cable was pulled out. I put it back in and hoped... But no! after unlocking the drivers door and Yay the passenger door opened too, BUT I could hear the pump ticking and I couldn't lock it again (air pressure I assume) and after the pump stopped ticking (about a minute) I could lock it again but the passenger door remained unlocked.
    So not quite there but I might have found out why it got disabled in the first place...
    95 SEAT Ibiza GTi
    the central locking on the Mk2's is air pressure as standard. normally when its 'disabled' the joints are pulled apart ... just check al joints are fully connected and it *should* work ok if you have heard the pump 'burring' away
    as for the black strip.. once they get water ingress there, they're more or less useless.. shame your so bloody far away as I have a set in my garden shed sitting gathering dust
    'Quod Me Nutrit, Me Destruit'.....
    www.seatcupra.net
    Aug 2007
    Horningsea Park
    If you have any Seat queries message Golf Loon, hes a wiz with any seat issues.
    Luke
    Aircooled & Watercooled Nut
    62 and a Half Bug
    02 Bora V5
    Aug 2007
    Quote Originally Posted by Lukev85 View Post
    Give us all a chance mate!! no offence but what are you trying to say???
    Alba European
    Aug 2007
    okay okay, look don't fight over it... I'll accept pointers from whom ever wants to give them... So thanks Jimmymac, and thanks Luke, and thanks Nightcrawler for almost offering to send me stuff from the UK! you guys rock!
    Tonight I got the car backed up into the tiny backyard with the light shining in so I might try to chase the air hoses arounf looking for a leak somewhere or a loose joint. keep the pointers coming though this has been heaps helpfull
    Update I could hear a hiss from the drivers door, so I'm concentrating efforts there. I removed the door trim panel, and found the door lock mechanism, but I think the problem might be with the control unit, which according to the Golf Haynes book that I downloaded, is located somewhere in the centre of the drivers door... I'm going to go back in there and try to find the hiss...
    95 SEAT Ibiza GTi
    Camden, Sydney
    Quote Originally Posted by Jimmymac View Post
    Youthfull enthusiasm I reckon Jimmy.
    I reckon you know more or as much about em as I do Jimmy. Its just a rare skill in Oz. There are only 3000 Seats here, so not many people have seen many of em.
    Nice to see someone with tech knowledge here Jimmy, you have the knowledge and will share it. I hope you continue to do so.
    PEACE.
    Aug 2007
    Okay I found the problem and I'm hoping it can all be fixed by applying some silicone... The driver door controller is just at the lock afterall, it simply has a leak between two parts. there is the little box (white flimsy plastic) where the power and air hose fit in, and that box fits into a bigger box of some sort (part of the lock also white plastic) and the connection between the two is leaking. the leak stops when I push the two togeter so I assume the O-ring thing between the two has worn. not wanting to exacibate the problem by taking it apart (and my attempt at it having failed) I think I'll just buy some silicone tomorrow and apply it to the connection.
    If I'm about to make a huge booboo let me know.
    Thanks all for pointing me in the right direction.
    95 SEAT Ibiza GTi
    Camden, Sydney
    The rectangular section in the CL door module may just click back on mate, if not, silicone will be ok.
    I ripped the rear plastic black strip off my old Ibiza GTI and painted the back. It was ok, but use black silicone to stick it back on, or it will show through.
