I have been looking for one of these too![]()
Does anyone run a short shifter on there cupra. If so any recommendations. Gruvenparts seems to have a good one neuspeed also has one but not sure if its suitable. Any suggestions would be appreciated
Thanks
Sent from my SM-G900I using Tapatalk
I have decided on the Gruvenparts short shifter with the b&m shifter
http://cdn1.bigcommerce.com/n-ww20x/...0.1280.jpg?c=2
B&M Manual Short Shifter, Precision Shifter, Audi, VW » B&M
Pretty sure they will work
Says B&M is out of stock!
Plenty of b&m on ebay also plenty of knock offs as well and to be honest they exactly the same. The only difference I noticed was a little blue paint and 150 bux lol
Keen to see how ya go!
Well I purchased the Gruvenparts short shifter and its on the way now. Also didnt go the b&m...I went the autobahn88 at $34. Im going to install the Gruvenparts short shifter first and then still in 2 minds about changing the actual shifter because read a few bad things. See how we go
Another option if you really want to improve the shift quality is swap the shift tower on your 02A gearbox with a later model 02J one. They work differently but will fit straight in (be sure to get the retaining cap from underneath though, its shift tower specific). You will then have to use the mk4 02J shifter and cables, but believe me the combination is just so superior to the 02A setup. Just another option, and there are probably a lot more upgrade parts available for a mk4/02J setup if you want to go further.
Thanks mate I will look into that
