Any help would be appreciated thanks!
Hey guys,
So in the next couple days ill hopefully be doing same service stuff for my car and i just need some help as mechanically im a bit of a NoOb.
What i would like to do is:
Change the fuel filter; Where do i find one for my 95 ibiza GTi?and what type of one do i need as in is there a special number like on an oil filter?
Change the oil; I know how to do this but was wondering is i want to replace oil bolt thing with a new magnetic one any1 know what size it is?
Change spark plugs and spark leads;I am buying platinum ones i think theyre 6-4 but what i was wondering what size/number are the leads for the same car?
Change Pod filter;This is pretty straight forward but i was wondering if there is a simple way to clean my MAF or should it be fine?
Heat sheild; In the next couple of weeks i was thinking of making a heat sheild for my pod filter out of tinted perspex; Has anyone done this or know of a link for a different site where they have?Or should i just go back to stock airbox with K&N Panel filter?
CAI; I want to put some type of cold air intake in the front of my car running to under the pod filter. I was looking for a way to go about it and was wondering if i can take off the driver side reflector thing at the bottom of my bar and run some piping up through the engine bay. If there is an easier place to run it through id love to know thanks.
Any help or advice with any of this would be much appreciated!
Thanks in advance from Lawrie
Pizza delivery Seat!
autobarn can help u with those special plugs and leads
they have good partsbooks and stock and will get things in like the magnetic plug
I dnt think that is needed if u change oil and filter at reg intervals..imo
saw a pod filter housed inside the std filterbox on a Mk3 and a pipe down to where u suggested.
was cool due to the box and prob more quiet.
btw i am dismantling a cordoba 95 if u are short on nicknacks doors lights etc etc
enjoy
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
Do you still have the steelies?if so will they fit my GTi and have they got good tread?
I have a K&N panel in the standard air box on my cupra but I opened up the front intake hole & increased the diameter of the cold air pipe that slots in behind the drivers side light, seems to work well & at least gave it a bit more intake sound.
Phil
Red 99 Seat Ibiza Cupra Sport, coilovers, K&N (Gone but not forgotten)
Blue 05 Golf 2.0 TDI DSG Comfortline, leather, sunroof.
2012 BMW X3 MSport 2.0D
Cheers cupra that was gunna be my next step as i read about some dyno tests run on a certain other Seat forum.
