i like the sound of this![]()
Right guys, I have this 1.4 Seat Ibiza that was running single point injection. The gearbox is rooted and new ones are expensive and the car is gutless anyway.
I also have a Golf 16v Mk2 engine and gearbox and am thinking I can make the beeza the b@stard child of VAG. And quite fast in the process![]()
Does anyone know how to make the fule pump work with Kjet? If is just a continuous running pump, can I use a kjet pressure accumulator and it will give the right pressure?
This is my major concern, other than that I reckon I have all the bits to make it work.
Any help or suggestions gratefully accepted.
how bout u put the 2L u are gunna put into ur golf. wack that into the ibiza and put the 1.8 into the golf![]()
All VAG pumps are continuous running.
But doesn`t kjet operate at a higher pressure than cis?Originally Posted by syncro
If I put a kjet accumulator in the system will that sort the pressure?
How about I put 1.8Ls in both cars. Minimal engineering.Originally Posted by GoLfMan
I have lots of 16vs at my house at the mo, so shout if you want one.
K-Jet is CIS. I think you meant EFI and the answer is yes.Originally Posted by Golf Loon
Yes, but would be better to match everything, including fuel line sizes.If I put a kjet accumulator in the system will that sort the pressure?
The Ibiza has pretty chunky fuel lines as standard, so I was gonna use them. Is wider Ok, or do I have to change to narrower ones for kjet? Surely not?
From memory the std K jetronic ( CIS) lines are 10 mm the pump you are using will need to deliver 900 millilitres in 30 seconds with at least 11.3 volts at the pump..Originally Posted by Golf Loon
System pressure is 68 - 78 PSI.
see how ya go, if u need it I can scan the page out of the bentley..
Lots of MK 1 Scirocco's...
Cheers,
Grant...
when I joined this forum Loon was building a mk1 Golf.
Suggestion
Why don't you finish what you started first.Stop getting off track.
Why put a 16v in a Seat when you can buy one already done by the factory and a home built one will never be as good as the Russell Morris and in the end would cost as much.
I want to see a mk1 on the road.
