Results 1 to 8 of 8
Thread: Help from VW/Seat gurus required for mystery problem
    Peregian Beach
    An unusual and annoying problem has developed out of the blue. My son parked the Cupra in the carport about 2 weeks ago and it was running perfectly at the time. In fact he had been driving to Gladstone and back once a week a round trip of around 1,100k's.
    When he started it up to drive it away it has developed an unusual misfire. It will run almost perfectly up to 2,400 rpm where it develops a random miss. The missing continues to about 3,500rpm when it clears and will rev cleanly to the red line. It is there every time and will even do it when free revving the engine ie not under load. It consistently starts at 2,400 rpm and you can drive it up to that point and you would not know there was a problem.
    Hopefully someone will have come across this before and have an answer. Any assistance will be greatly appreciated as we have spent over 4 hours swapping bit over from my Cupra with no solution. My Vchecker could not find any trouble codes.
    Jun 2009
    Sunshine Coast, Queensland
    I would be looking for an ignition HV fault like a spark plug lead or a distributor cap arcing across.
    In a dark garage with the bonnet up look for blue arcing around the leads or cap or coil do it night if you have to
    Jun 2009
    Beaumont Hills
    I agree, my cordoba did the same thing last year. changed the spark plug leads and distrubtor cap and ignition coil. problem gone after that..
    I believe the igition coil was worn out and I think that was the main problem, she would get to 80km and then just couldn't get her to go any faster
    1995 Seat Cordoba - Red GLX -Written Off
    1995 Seat Cordoba - Red GLX - Sold
    1995 Seat Cordoba - Silver GLX Fell Apart
    1996 Seat Cordoba GLX - White - Going Strong
    Aug 2007
    Yep , put the vchecker back in the tool box and start with the basics. Major problem these days people relying solely on a scanner, seen it many times in the dealerships guy scratching his head looking at a scanner saying no codes and the car misfiring. His response was the scanner says there is nothing wrong. Really???Ok customer must have been needing a car park in the dealership for the day. Take all the fancy systems away and you have an internal combustion engine that needs fuel air and a spark at the right time to run right.
    Good luck
    Jmac
    Alba European
    Peregian Beach
    Thanks for the suggestions guys. As I have a second Seat I have swapped most things over from the one going well and so far no luck. My mate has had a car computer guru to have a look at the ECU and he reckons there is a problem with it. I am dubious because I had a spare non immobilisered (is that a word?) ECU. We put that in and it changed the problem. It still had a miss but lower in the rev range which made it a bit easier to drive at 80-100 kph. After I put the repaired ECU back in it if isn't right I will put a new coil in it and see what happens.
    Special thanks to Gav for his assistance in scanning and other fiddling that we tried.
    Quote Originally Posted by Bora Sport View Post
    But I never fixed it.
